beachymomma
#1 Posted : Monday, January 14, 2013 1:58:31 PM(UTC)
beachymomma
Hi, all of of sudden ice maker stopped working. Water coming out for drinking water, once in a while an ice cube would kinda get stuck sideways and I could always clear out. Using previous posts, when I close flapper door, red light stays on for laser. Can I remove unit to investigate?:(
#2 Posted : Tuesday, January 15, 2013 1:28:12 AM(UTC)
Close the flapper and the light switch. Optics led should go out, if not, you may have a bad optics board or a bad wire to the optics receiver board. If it stays lit it still could be bad optics or a bad wire.
To test the icemaker, remove both optics boards and place a thin wire jumper between the black and black/white wires going to the receiver connector. If the icemaker mold has no water,go in the back of the fridg and temporarily reverse the connectors on the dual water solenoid, close the freezer door and push the water switch for 7 to 9 seconds. icemaker mold should now fill with water. If ok and the freezer temp is below 15 degrees, icemaker should work. If not you probably have a bad icemaker. If not check for a frozen water line or a bad water solenoid.
Let us know if you can check things with a meter.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
