| » GE Profile Refrigerator Condensor fan |
Model Number: PFS22miwbb Brand: GE Age: 1 - 5 years
Refrigerator and Freezer quit cooling. Compressor makes clicking sound but is real hot. Fan on condenser turns real slow. Any suggestions as to what problem might be? Is condenser fan supposed to fun faster?
Hi.
Cool down the compressor, remove the start devise and check continuity between the 3 compressor's pins (continuity between all three of them).Next check one of the pins to the ground - you should have no continuity. Next check if there is 120VAC to the start devise between two wires going to it. If there is proper voltage - replace the start devise Part number: WR07X10097 If there is no voltage - replace the control board Part number: WR55X10942 Here are the breakdown diagrams and Cabinet parts for GE PFS22MIWBBB - AppliancePartsPros.com Take the opportunity while you are there and clean the condenser coils. Post the result. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Yes the fan should be running fast. I suspect the board isn’t sending full power to the fan. See if it appears the fan in the freezer is running slowly too. If so you can be sure the board is bad. If the freezer fan is running fine check voltage to the condenser fan as well as fan motor supply voltage. If the fan is getting correct voltage but running slow as you describe replace the fan but if the fan isn’t getting correct voltage replace the main board. This page has instructions and pictures that should help with this. GE Refrigerator Fan Motor Diagnostics |
Replaced compressor relay. Voltage to compressor fan is 14. Have ordered new fan motor. While waiting for motor I have placed small fan to blow on compressor and coils. Refrigerator and freezer are cooling like they should. Great suggestions and directions. Thanks.
Hi.
Make sure the condenser coils are clean and the cover is in it's place. Simon.
__________________
Have received new condenser fan motor. It runs slower than old motor. Rechecked the voltage and get 13.6v for both the supply and fan tests. New motor will not turn when held with the fan facing the coils but will slowly turn when held with fan facing up or down. Strange! Any suggestions.
Hi.
You should replace the main control board together with the motor and BTW get another condenser motor. Simon.
__________________
Keep us posted.
Simon.
__________________
| Display Modes | |
| Refrigerator condensor motor | Donny64 | Refrigerator & Freezer Repair | 2 | 08-15-2011 05:03 AM |
| GE Profile refrigerator-warm freezer & refrigerator | ykim4492 | Refrigerator & Freezer Repair | 2 | 02-14-2010 05:52 PM |
| GE Profile Refrigerator - freezer cold but refrigerator not | EricNJCPA | Refrigerator & Freezer Repair | 1 | 11-23-2009 05:51 PM |
| GE profile condensor fan not working | dcampbell | Refrigerator & Freezer Repair | 8 | 04-25-2009 07:53 PM |
| GE Refrigerator/Freezer Condensor fan motor not working | Brian Mosdal | Refrigerator & Freezer Repair | 6 | 02-03-2009 04:44 PM |
