Discuss
EdgeStar wine fridge problem.
 in
Refrigerator & Freezer Repair
Thank god I found this place. Maybe someone can help. I recently bought THIS wine fridge off a guy on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » EdgeStar wine fridge problem.
  #1 (permalink)
Old 01-12-2013, 09:44 PM
Junior Member
Chris1337 is on a distinguished road
Default EdgeStar wine fridge problem.
Model Number: TWR215ESS   Brand: -other-   Age: 1 - 5 years
I recently bought THIS wine fridge off a guy on craiglist. I got it home and fired it up and noticed a problem a bit later*I know I should have tried it out first *
The top partition control does not work right. If I adjust the temperature to say to 50 degrees, it will keep beeping and going up a degree sporadically until it is back at its max temperature 66 degrees. Then it will continue to beep for up to days randomly and if I try to adjust it, it does not register anything. It seems like it thinks I am pressing the button so perhaps a short or something. Anyone know of a safe way I can try to address this problem.
This thing was not cheap and 66 degrees is much to high for my wine. The bottom half works perfectly.
Thanks in advance for any help!
UPDATE- I just took a closer look. Im even more concerned because I noticed that the temperature it says on the display and the temperature it inside are off. Its about 5 degrees warmer on the inside. Everytime it beeps, the fan stops for a second and starts up again. The lights on the display flicker aswell
Ads By Google
Related Models
Frigidaire TWX233RBD0 Tap(v4) / 27 " Washer
Frigidaire TWX233RBD1 Tap(v1) / 27 " Washer
Frigidaire TWX233RBD2 Tap(v1) / Top Load Washer
Frigidaire TWX233RBD3 Tap(v1) / Washer
Frigidaire TWX233RBW0 Tap(v3) / 27 " Washer
Frigidaire TWX233RBW1 Tap(v2) / 27 " Washer
Frigidaire TWX233RBW2 Tap(v2) / Top Load Washer
Frigidaire TWX233RBW3 Tap(v2) / Washer
Frigidaire TWX233REW1 Frg(v0) / Washer
Frigidaire TWX645RBD0 Tap(v2) / 27 " Washer
Frigidaire TWX645RBD2 Tap(v3) / Top Load Washer
Frigidaire TWX645RBD4 Tap(v1) / Washer
Frigidaire TWX645RBW0 Tap(v1) / 27 " Washer
Frigidaire TWX645RBW1 Tap(v3) / 27 " Washer
Frigidaire TWX645RBW2 Tap(v4) / Top Load Washer
Frigidaire TWX645RBW3 Tap(v0) / Washer
Frigidaire TWX645RBW4 Tap(v2) / Washer
Amana TX18J Ref - Top Mount
Amana TX18K Ref - Top Mount
Amana TX18K2 Ref - Top Mount
Amana TX18M Ref - Top Mount
Amana TX18MB Ref - Top Mount
Amana TX18N Ref - Top Mount
Amana TX18NB Ref - Top Mount
Amana TX18Q2L Ref - Top Mount
Amana TX18Q2W Ref - Top Mount
Amana TX18QB2L Ref - Top Mount
Amana TX18QB2W Ref - Top Mount
Amana TX18QBG Ref - Top Mount
Amana TX18QBL Ref - Top Mount
Amana TX18QBW Ref - Top Mount
Amana TX18QG Ref - Top Mount
Amana TX18QL Ref - Top Mount
Amana TX18QW Ref - Top Mount
Amana TX18R2L Ref - Top Mount
Amana TX18R2W Ref - Top Mount
Amana TX18RL Ref - Top Mount
Amana TX18RW Ref - Top Mount
Amana TX18VC Ref - Top Mount
Amana TX18VE Ref - Top Mount
Amana TX18VL Ref - Top Mount
Amana TX18VW Ref - Top Mount
Amana TX19R2E Ref - Top Mount
Amana TX19R2L Ref - Top Mount
Amana TX19R2W Ref - Top Mount
Amana TX19R3E Ref - Top Mount
Amana TX19R3L Ref - Top Mount
Amana TX19R3W Ref - Top Mount
Amana TX19RE Ref - Top Mount
Amana TX19RL Ref - Top Mount
Amana TX19RW Ref - Top Mount
Amana TX19S3E Ref - Top Mount
Amana TX19S3L Ref - Top Mount
Amana TX19S3W Ref - Top Mount
Amana TX19V2E Ref - Top Mount
Amana TX19V2L Ref - Top Mount
Amana TX19V2W Ref - Top Mount
Amana TX20J Ref - Top Mount
Amana TX20K Ref - Top Mount
Amana TX20M Ref - Top Mount
Amana TX20MB Ref - Top Mount
Amana TX20N Ref - Top Mount
Amana TX20NB Ref - Top Mount
Amana TX20QBG Ref - Top Mount
Amana TX20QBL Ref - Top Mount
Amana TX20QBW Ref - Top Mount
Amana TX20QG Ref - Top Mount
Amana TX20QL Ref - Top Mount
Amana TX20QW Ref - Top Mount
Amana TX21A3E Ref - Top Mount
Amana TX21A3L Ref - Top Mount
Amana TX21A3W Ref - Top Mount
Amana TX21R2E Ref - Top Mount
  #2 (permalink)
Old 01-13-2013, 10:50 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot be of much help but can at least supply you with some info on it.
Here is a manual for it. It does have basic wiring diagram.
http://demandware.edgesuite.net/aabh...ESS_manual.pdf
Here is a board for it. There is also some basic info in the support section.
EdgeStar Replacement Circuit Board for TWR215ESS TWR210EBL and TWR125S
Looks like there are 2 boards for controlling the temperatures.
You could try swapping the boards to see if the top now runs OK. Problem here ius that you may blow a good board if the problem is caused by something connected to the board.
Remove the board and check for a cold solder joint.
Cold solder joints are often a duller silver and/or may have pin holes.
Also gently wiggle the components to see if their legs move in the solder on the solder side.
A magnifying glass comes in handy here.
Check the capacitors (black cans with silver tops) for any leaking or bulging.
Check that the thermistors (NTC) are the same for top and bottom with a meter. ote meter polarity may make a difference here so try both polarities.
__________________
  #3 (permalink)
Old 01-13-2013, 11:23 AM
Junior Member
Default
Thanks for all the great info. I figured I was going to have to get down into this thing to get it working again. My biggest concern is just breaking the whole thing haha
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Urbina Design Wine Fridge cassonclef Refrigerator & Freezer Repair 1 10-28-2012 05:39 AM
Wine fridge no longer cooling Gayle V Refrigerator & Freezer Repair 1 07-20-2012 04:23 AM
wine cooler problem mhawes47 Refrigerator & Freezer Repair 1 07-17-2010 06:53 AM
Wine fridge no longer cooling aktaylors Refrigerator & Freezer Repair 0 01-19-2010 03:20 PM
Wine Fridge not Cooling jhsneed Refrigerator & Freezer Repair 7 12-17-2009 02:55 PM
