Freezer Cold But Fridge isn't after replacing main control board
Brand: GE Age: 5 - 10 years
Main control board had a blown fuse so replaced. Now freezer works but fridge isn't as cold. When I replaced board the lower circuit pins are pointing upwards and right against plate, old board the pins were facing downward, would this have anything to do with it?
Also which pins are responsible for cooling fridge? so i can check if which pins I should reseat. Trying to not solve one problem and introduce another so would be good to know what all the cables are for.
I've seen other posts similar to mind but haven't seen a response by anyone so hope that someone can help me. Appreciate it.
Ads By Google
