| » Water not going into ice maker |
Model Number: KSUP25QDWH01 Brand: Kitchen Aid Age: More than 10 years
Just curious where to start troubleshooting this. The ice maker goes through its cycle, but water never goes into it to get frozen. There is no filter on this refrigerator. Any suggestions would be greatly appreciated. This has been a FANTASTIC refrigerator for us. Over 10 years old and this is the first significant issue we've had!!
Thanks in advance! Ads By Google Related Models |
Hello,
Make sure the water tube which comes into the ice maker is not blocked with ice inside. If it is, defrost it using a hair dryer. Locate the water inlet valve on the back of the refrigerator and swap the wires between the solenoids. You can use an insulated wires to connect the plug to the small terminals. Push the water dispenser lever for a few seconds and check for water in the ice maker. if there is water, replace the ice maker. If there is no water, replace the water inlet valve. - The water inlet valve Part number: 2188542 - The ice maker (you have to use the old bail arm and the head cover) Part number: W10190965 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
| Display Modes | |
| Can You adjust water flow for Maytag ice maker #95109-1. ( Older ice maker) | 11charm34 | Refrigerator & Freezer Repair | 0 | 09-02-2012 11:49 AM |
| Kenmore Ice Maker --no ice--maker or water control valve | cps.extra | Refrigerator & Freezer Repair | 0 | 08-13-2011 08:59 AM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:27 AM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:20 AM |
| Replaced Ice Maker and noid and still no water to ice maker | darrewhite | Refrigerator & Freezer Repair | 0 | 05-17-2009 06:34 AM |
