no ice no water-frigidaire
no ice, no water, from freezer door dispenser. appears that there is no power to door (no lights at all). checked electric connecter on upper door hinge-looks ok. any suggestions on what to do?
paul |
Hi, Paul.
Please check the freezer door switch. Power to the dispenser control is supplied through that switch. You should read continuity between C and NO when switch is pushed in. The light switch Part number: 241547901 Here are the breakdown diagrams and Cabinet parts for Frigidaire GLHS68EEB4 - AppliancePartsPros.com Post the results. Simon. |
checking freezer door switch
any way to remove switch from freezer side or do i have to go in from the back of the freezer wall? in photo it looks like there is a "catch", dont know to get to it.
paul |
Hi.
Yes, there is the catch on one side of the switch.Use a putty knife and flat screwdriver to pop it out. Unplug the fridge while doing it. Simon. |
freezer switch
Quote:
i got the switch out, and there is continuity between C and NO, when i push the switch in. what else do i need to check? paul |
HI.
Based on the information you provided the power board should be replaced Part number: 241708102 Simon. |
repair question
i got the part you suggested, any hints on disassembling the dispenser without breaking anything. are there screws under the button cover or does the cover pop off (catches?), etc
paul |
Hi.
If you pull out the drip tray you'll see screws holding the frame. Simon. |
power board
Quote:
paul |
Hi.
Check if you are getting 120VAC to the power board between Red/Blk and LtBlu? If you do then check the harness ribbon and replace the switch control board Part number: 241708306 You can return the power board for full refund. Post the results. Simon. |
| All times are GMT -7. The time now is 04:52 AM. |
