| » home owner |
Model Number: bc20jl Brand: Amana Age: More than 10 years
When my refrig. comes off defrost it makes a clicking noise
at least 3-4 times before the compreesor starts. Does not do this on normal starts. I put a watt meter on it and when it clicks and does not pull hardly any more watts. like it wound if the compressor was trying to start. I changed out the defrost unit ,no help. What's next the overload relay ? Thank's Wayne Ads By Google Related Models |
Hi Wayne, it's not watts you want to check but amps. It sounds like the relay/overload/start device may be faulty. I can't get anything to come up with that number. Read it off the tag in the fresh food section and not off any stickers on the door.
__________________
Ricks Appliance Repair |
Here is the model from the label in side the box.
Model BC20JL Amana Mgf # P7680812WL sn. # 8701025320 I looked at watts and anps, didn't pull much trying to start not as much as running normal, which is about 8/9 amps Thank's Wayne |
8 or 9 amps running? That's way too much. I don't know why I can't get anything to come up with that number. Are you in the USA? Try replacing the start device. It's either that or the compressor.
__________________
I told you wrong on the amp draw while running is 3 amps
defrost amps is 4 When it tries to start after defrost mode it jumps to 20 amps and kicks out, does this serveral times before the compressor starts. I haven't recorded amps on normal start. Thanks, Wayne I have since recorded start amps it's 3 amps. Last edited by wayfran67@q.com : 01-15-2013 at 07:47 AM. Reason: update |
| Display Modes | |
| home owner | gregmark | Microwave Repair | 0 | 11-26-2011 03:37 PM |
| Home Owner | kdchase | Washer Repair | 1 | 03-30-2011 09:48 AM |
| Home Owner | kdchase | Washer Repair | 1 | 03-27-2011 05:51 PM |
| home owner | AtollMan | Washer Repair | 3 | 09-12-2010 06:42 PM |
| home owner | louismok | Oven Repair (including Ranges and Cooktops) | 2 | 08-09-2010 06:29 PM |
