Discuss
Need To Repair Rubber Seal
 in
Refrigerator & Freezer Repair
HOW DO U REPLACE RUBBER SEAL AROUND DOOR.AND WHERE CAN U FIND IT.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need To Repair Rubber Seal
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-13-2007, 05:05 PM
stanley stanley is offline
Junior Member
stanley is on a distinguished road
Default Need To Repair Rubber Seal
Model Number: ET14JKXMNRO   Brand: Whirlpool   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-14-2007, 05:41 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
If you open the door and look under the door seal you will see the screws that hold it in place.
I have found it is best to take the door off and find someplace you can lay it flat to work on it.
For example on a table with the door handle hanging over the edge.
If you do not have it laying flat the door will tend to twist on you as you take it apart.
You do not have to remove the door gasket screws all the way, just losen them up enough to pull the old gasket out and then slip the new one in.
Just click on the model number on top your first post to find the correct door gasket for that model.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
front seal bellow on WPL Duet MGARRETT278 Washer Repair 2 04-01-2008 04:16 PM
Maytag Washer Bottom of tub leaking at seal David S Washer Repair 4 08-10-2007 11:16 PM
dryer felt seal Betty Roth Dryer Repair 0 07-25-2007 06:18 PM
loose seal used upright freezer tcarlson762 Refrigerator & Freezer Repair 1 07-24-2007 11:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
