Water does not dispense, ice maker working normally. Replaced water inlet/dispense valve, since water supply was clearly working since ice maker works, checked continuity of wiring from switch to solenoid and switch for on/off operation. Still no water flow, but I can feel the solenoid activate when the switch is pushed. Water reservoir does not appear frozen and lines look clear. Any help will be appreciated.
Originally Posted by: pentangle Water does not dispense, ice maker working normally. Replaced water inlet/dispense valve, since water supply was clearly working since ice maker works, checked continuity of wiring from switch to solenoid and switch for on/off operation. Still no water flow, but I can feel the solenoid activate when the switch is pushed. Water reservoir does not appear frozen and lines look clear. Any help will be appreciated. I f unit has water filter,it may need to be changed. Also unplug j guess fitting under bottom hinge and then engage dispenser switch and see if u have pressure there,water line may be frozen in the door. Hope this helps!
I had replaced the water filter and it worked for a couple of days, I will check the water line in the door, hadn't looked at that yet. Any idea where I can find a service manual for the fridge?
Frozen line in the door, thawed it, now have good flow, thanks!
