My frig is warm up top and actually freezing the milk on the door and veggies in the crisper on the bottom of the frig. The freezer compartment is also warm up top and allowing food to thaw. Food below the top shelf is solid as a rock. Middle section of frig and freezer seem to be the correct temp. Is there a circulating fan that is not working?
Thoughts...suggestions...solutions?
As always...thank you in advance for any and all advice that you share.
Scott
I am having the exact same problem you are describing. Did you find out what the problem is?
I heard there were some models of GE Refrigerators that were recalled for the motherboards. Is this model included in that recall?
