| » Whirlpool Side by Side Ice maker not making ice. |
Model Number: GD5PHAMMS10 Brand: Whirlpool Age: 1 - 5 years
I have a whirlpool side by side refrigerator that has stopped making ice. The refrigerator is approximately 3 years old. The problem is that it is not putting ice to the ice maker. I switched the plugs from the valve that puts water to the door. When I press the paddle on the door for water dispense it will put water to the ice maker. What do I need to be looking at for a problem part. Thanks in advance for any help you can give me.
Bobby Correction on the model number it is GD5PHAXMS10 Last edited by robert72 : 02-03-2008 at 01:18 PM. Reason: EDITINT MODEL # |
Hi Bobby,
Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side. Post your findings. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
knightto,
Looks like the optics gone bad. I need the complete model number of the refrigerator for more accurate advise. Gene.
__________________
Hi guys
I am having the same problem. My ice maker is nog making ice and I'm suspecting the infrared receiver. I did this simple test: I switch the ice mode off, and on. Then I open the door and the infrared light stays red for a long time and then goes off. When I press the flap on the other side, the light stays off. It doesn't seem as if there is any water in the water line going to my ice maker, at the back of the fridge. I'm in the country, and no one here has the computer where you plug it in and it tells you what the problem is. I've been told to replace my pc board as that might be the problem. It could also be the solenoid, I'm told. No one has even mentioned anything about the ir receiver/sender that might be faulty. Thanks. |
The first thing I would do in such situation is replace the optic boards. In order to provide the correct part number we need the complete model number of the refrigerator.
__________________
| Display Modes | |
| Amana side-by-side refrigerator ice maker. | Larry.Jenkins | Refrigerator & Freezer Repair | 1 | 01-28-2008 01:00 PM |
| Ice maker in door side by side will not dump | txrex11 | Refrigerator & Freezer Repair | 1 | 12-17-2007 10:13 PM |
| Whirlpool Side By Side Ice & Water Dispenser | jimpasquale | Refrigerator & Freezer Repair | 1 | 10-31-2007 04:44 PM |
| Whirlpool side by side not making ice | nuuch | Refrigerator & Freezer Repair | 3 | 09-09-2007 11:39 PM |
| Frigidaire side-by-side ice maker | bittersweet | Refrigerator & Freezer Repair | 0 | 08-12-2007 12:27 PM |
