Discuss
Whirlpool Side by Side Ice maker not making ice.
 in
Refrigerator & Freezer Repair
I have the same problem here? anyone know what the solution is? When i close the flap for the infrared
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Side by Side Ice maker not making ice.
  #11 (permalink)
Old 10-15-2011, 02:31 PM
Junior Member
fivestarslarry is on a distinguished road
Default Same problem here?
I have the same problem here? anyone know what the solution is? When i close the flap for the infrared sensor the light stays solid red, the ice maker is not filling the maker with water? the water to the water dispenser works just fine,any ideas?
Ads By Google
  #12 (permalink)
Old 10-17-2011, 02:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the refrigerator?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 10-17-2011, 03:38 PM
Junior Member
Default Model #
The model # is GS6SHAXMQ00model #
  #14 (permalink)
Old 10-17-2011, 07:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Make sure the water tube into the ice maker is not clogged. Locate the water inlet valve on the back of the refrigerator and swap the wires between the solenoids. Depress the water dispenser release lever for a few seconds and check for some water in the ice maker.
If there is no water, replace the water inlet valve.
If there is water, replace the ice maker.
- The water inlet valve Part number: AP3160649
- The ice maker Part number: AP3182733
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GS6SHAXMQ00 REFRIGERATOR | AppliancePartsPros.com
__________________
  #15 (permalink)
Old 10-24-2011, 02:58 PM
Junior Member
Default Still no ice
OK i did both as indicated above , switched the wires on the inlet valve and water filled the ice maker. I replaced the ice maker 2 hours ago and still no ice its not filling with water , how do i know if i need to replace the optics board?
  #16 (permalink)
Old 10-26-2011, 01:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry for the delay.
Pull the ice maker out but do not unplug it. Remove the head cover and check for 120 VAC between the "L" & "N" test points. Post the result.
__________________
  #17 (permalink)
Old 10-26-2011, 02:01 PM
Junior Member
Default
Ok got 120 VAC between L and N.
Let me clarify the post earlier, I switched the wires on the valve on the back of the fridge and depressed the water dispenser and water started filling the ice maker, the optics light when i open the fridge blinks a few times , when i hold the flap closed it stays solid red. I replace the ice maker and still no ice
  #18 (permalink)
Old 10-26-2011, 02:25 PM
Junior Member
Default
I read somewhere if i jump V and L with a wire that it should turn on the valve to fill the ice maker? I did that and NO water? so is it the valve? I also jumped T and H that i read was supposed to start a cycle it did not?
  #19 (permalink)
Old 10-28-2011, 04:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Do the following:
1. Jump test points “T” to “H”.
2. Make sure the ice bin is on the door, the slide switch is “on,” and both doors are
closed.
3. Unplug the unit, or turn off the power for 10 seconds, and then reapply power.
4. After 10 seconds, open and close the freezer door.
5. After 15 seconds, open the freezer door. The ice maker should be running.
6. Remove the jumper from test points “T” to “H”.
and post the results.
__________________
  #20 (permalink)
Old 11-02-2011, 11:31 AM
Junior Member
Default
ok i jumped "T" and "H" it didn't do anything
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Side by Side Quit making Ice rburns30066 Refrigerator & Freezer Repair 2 08-11-2009 06:44 PM
Whirlpool Side-by-Side ice maker overfills, water runs over into freezer... threefivezero Refrigerator & Freezer Repair 1 07-06-2009 07:00 AM
whirlpool side by side ice maker in door - not making ice longhornp Refrigerator & Freezer Repair 1 06-11-2009 05:41 AM
Whirlpool side by side Ice maker spews water into freezer fraserm General Talk 3 12-06-2008 08:19 AM
Whirlpool side by side not making ice nuuch Refrigerator & Freezer Repair 3 09-09-2007 10:39 PM
