I have a Whirlpool Gold S/S model number gd5shaxmq00. The freezer is not longer cold. Everything has melted. I took apart inside reaer of the freezer to check the coils for ice and there was none the fan was running fine. I removed the back of the fridge panel and looked for refridgerant leaks and found none. I can here the compressor turning on and off periodically but I dont have enough experience to know if that makes a difference. We initially had tooo much stuff in the freezer and fridge not allowing the air to circulate so I dont know if that was the problem. Please help.
Most probably a bad start device 2319792, just order it on this site.
