I have a Balck Frigidaire/Electrolux PLHT19WEL4 Refrigerator. The doors were swapped so the hinges are on the left, but the doors do not align properly. Is there a different hinge or adapter that is required to realign the doors when the swap over is done? It appears the hinge itself does not align the same when turned 180 degrees. Any tips or help here is much appreciated. Thanks, Ken
