Unit has shut down, Lights work fan and comp dont. Relay on motherbaord is clicking. Unit was fine yesterday, last time I know it worked I had gotten ice from door, door was slightly ajar and had to push (Lightly 7-10 lbs pressure) unit then worked and has not since. Is there anything i can do to verify if the problem is in the door or motherboard?
Seems like a bad motherboard WR55X10942
Originally Posted by: richappy Seems like a bad motherboard WR55X10942 Because of xmas wont be able to get parts for several days. Is it possible to disconnect motherboard and manually operate the compressor and fan?
It is possible the evaporator thermistor opened from thermal stress. If so, the unit would hang up in defrost. Most appliance repair places would have one. Thermistor should be around 16.8 kohm at 32 degrees (ice water).
