| » KitchenAid Refrigerator Too Cold |
Model Number: KBCA06XPBS00 Brand: Kitchen Aid Age: 5 - 10 years
My KitchenAid refrigerator runs continuously and gets very cold, whichever setting I use.
I checked the coils and they are clean. I also changed the thermostat for a new one. I checked and the seal is good and the light switch is in the proper position. Here is what happens: - Refrigerator runs continuously and temperature is colder than what I need, despite the setting being on the highest temperature - If I switch off the refrigerator using the temperature control to the "off" position, and then switch it back on, then the cooling system does not start. - Once the refrigerator starts warming up (after several hours), then the cooling system starts again and will not stop. I am tempted to buy a timer which will program the refrigerator to switch off every so many hours but I would rather find a proper solution to the problem. Any suggestion? Ads By Google Related Models |
Quote:
It's a refrigerator only - no freezer section. I checked the temperarature with a refrigerator thermometer and it shows 30. I am not convinced of the accuracy so I am going to try again with water. |
Ok, all evidence points to a sticking cold control 4344725 You can try spraying the control with non-residue contact cleaner available at Walmart, just turn the control while spraying.
__________________
| Display Modes | |
| Magic Chef Refrigerator Freezer work Refrigerator not cold enough | tg06222 | Refrigerator & Freezer Repair | 1 | 09-05-2011 03:56 AM |
| Refrigerator/freezer not staying cold, then too cold | wendymay | Refrigerator & Freezer Repair | 0 | 03-31-2011 06:40 PM |
| Kitchenaid not cold enough | element192 | Refrigerator & Freezer Repair | 0 | 03-14-2011 05:37 PM |
| Freezer cold but not freezing, Refrigerator cool but not cold | sixboyzdad | Refrigerator & Freezer Repair | 1 | 06-09-2010 09:00 PM |
