I plan to get the Fridiaire bypass plug cartidge (PN 242227702) but in the interim, can I bypass the water filter at the triple solenoid valve (PN 241734302) itself by either:
1) Adapting the copper supply line and connecting it directly to the water filter inlet nipple on the valve, or 2) connecting a tube directly from the water filter outlet nipple to the water filter inlet nipple on the valve.
If so do I even need the bypass cartridge?
Thanks in advance.
