Freezer working but fridge is getting warm. I pulled the back of the freezer off and coild were frozen. I replaced the thermostat attached to the coils, the heater at the bottom of the coils and melted all of the ice. The fridge immediately got cold, but its a week later and the same problem. Coils are frozen. What else is left? Could it be the motherboard?
Remove the motherboard cover and remove the 3 pin,gray power connector. Put a wire jumper between the mating pins as labled on the motherboard, (line and def.) Plug in fridg, defrost should start, assuming the freezer was cold. If not, you probably have a wiring problem in the freezer, assuming you replaced the defrost thermostat and heater. If defrost action, replace the motherboard WR55X10942
