Discuss
How do I confirm a PTC Starter Relay is Bad?
 in
Refrigerator & Freezer Repair
Can someone help me confirm that my PTC Starter Relay is bad? I have a 7 year old Everstar Wine
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » How do I confirm a PTC Starter Relay is Bad?
  #1 (permalink)
Old 12-13-2012, 08:14 PM
Junior Member
dwclapp is on a distinguished road
Default How do I confirm a PTC Starter Relay is Bad?
Model Number: HDWC35 - Everstar   Brand: -other-   Age: 5 - 10 years
I have a 7 year old Everstar Wine Cooler model HDWC35, also sold as Franklin Chef model FBC35OD. The compressor won't start and I believe the PTC starter relay is bad. Before I buy a new relay, I've run some test that I hope confirm the old relay is bad. Can you offer any reassure that I'm reaching the correct conclusion, or redirect me if I'm off in the weeds?
The compressor windings seem to be ok. The ohms between the 3 compressor terminals are 5.6, 6.2 and 11.3. I think 5.6 is between the common and run terminals, 6.2 is between the common and start terminals, and 11.3 is between the start and run terminals. (could be wrong in the labels - this is the 1st compressor I've worked on and I'm learning from blogs & youtube what to look for). Also, there aren't any shorts between any of the 3 compressor terminals and the compressor's metal housing, since I get infinite resistance / ohms between each of the three compressor terminals and the metal housing.
When I power up the refrigerator, as soon as the fan starts (~5 seconds after power-up), the PCT relay (now unplugged from the compressor) reads 120 volts between common and start, 120 volts between common and run, and 0 volts between the start and run. I connected two light bulbs, one between common and run, the other between common and start. Supposedly if the PCT is working, the start bulb should at least blink on and the run bulb should stay on. Unfortunately the start bulb does not blink, and no voltage registers between the start and common leads, not even a blip when the fan and run light turn on. Only the fan and run light turn on simultaneously, but the start light does nothing, which I think means the PCT is sending 120 volts to the run lead when there is no load / no bulb, and 0 volts when there is a load / bulb between the start and common leads.
Yes, I tried the shake test, but don't get any rattling noise from the PCT relay.
The only other test I can think of doing is manually applying 120 volts to the start lead to see of the compress runs with a little kick start. If 'yes', I believe that would confirm the problem is a faulty PCT relay that fails to apply 120 volts to the start lead long enough to start the compressor.
Am I on the right track? Any other ideas to test my suspicion about the PCT relay being bad?
FYI, I think I found a replacement PCT relay on fixice.com, part #1858460700 for $15. Is there a better place to get these cheaper? The compressor is a Zel OF789D, and the old PCT relay part says TY 3012-5A 110-115V, A1C7 Cubigel SA.
Thanks for your help and patience with my novice learning.
dwclapp
Related Models
Amana HE-10 COMMERCIAL MICROWAVES
Amana HE-3000 COMMERCIAL MICROWAVES
Amana HE-5000 COMMERCIAL MICROWAVES
Amana HE1203 WASHER-TOP LOADING
Amana HE1243 WASHER-TOP LOADING
Amana HE2003 DRYER- ELE
Amana HE2030 DRYER- ELE
Amana HE2050 WASHER-TOP LOADING
Maytag HE21230T ELECTRIC WATER HEATER
Maytag HE21230T961 ELECTRIC WATER HEATER
Maytag HE21230T961CSA ELECTRIC WATER HEATER
Maytag HE21230TCSA ELECTRIC WATER HEATER
Maytag HE21240S ELECTRIC WATER HEATER
Maytag HE21240S961 ELECTRIC WATER HEATER
Maytag HE21240S961CSA ELECTRIC WATER HEATER
Maytag HE21240SCSA ELECTRIC WATER HEATER
Maytag HE21250PC ELECTRIC WATER HEATER
Maytag HE21250S ELECTRIC WATER HEATER
Maytag HE21250S961 ELECTRIC WATER HEATER
Maytag HE21250S961CSA ELECTRIC WATER HEATER
Maytag HE21250SCSA ELECTRIC WATER HEATER
Maytag HE21250T ELECTRIC WATER HEATER
Maytag HE21250T961 ELECTRIC WATER HEATER
Maytag HE21250TCSA ELECTRIC WATER HEATER
Maytag HE21282PC ELECTRIC WATER HEATER
Maytag HE21282T ELECTRIC WATER HEATER
Maytag HE21282T961 ELECTRIC WATER HEATER
Maytag HE21282T961CSA ELECTRIC WATER HEATER
Maytag HE21282TCSA ELECTRIC WATER HEATER
Amana HE2250 WASHER-TOP LOADING
Amana HE2430 WASHER-TOP LOADING
Maytag HE2830T981 ELECTRIC WATER HEATER
Maytag HE2830T981CSA ELECTRIC WATER HEATER
Maytag HE2840L960 ELECTRIC WATER HEATER
Maytag HE2840L960CSA ELECTRIC WATER HEATER
Maytag HE2840S981 ELECTRIC WATER HEATER
Maytag HE2840S981CSA ELECTRIC WATER HEATER
Maytag HE2840T981 ELECTRIC WATER HEATER
Maytag HE2840T981CSA ELECTRIC WATER HEATER
Maytag HE2850S981 ELECTRIC WATER HEATER
Maytag HE2850S981CSA ELECTRIC WATER HEATER
Maytag HE2850T981 ELECTRIC WATER HEATER
Maytag HE2850T981CSA ELECTRIC WATER HEATER
Maytag HE2866T981 ELECTRIC WATER HEATER
Maytag HE2866T981CSA ELECTRIC WATER HEATER
Maytag HE2930T ELECTRIC WATER HEATER
Maytag HE2930T981 ELECTRIC WATER HEATER
Maytag HE2930T981CSA ELECTRIC WATER HEATER
Maytag HE2930TCSA ELECTRIC WATER HEATER
Maytag HE2940L ELECTRIC WATER HEATER
Maytag HE2940L960 ELECTRIC WATER HEATER
Maytag HE2940L960CSA ELECTRIC WATER HEATER
Maytag HE2940LCSA ELECTRIC WATER HEATER
Maytag HE2940S ELECTRIC WATER HEATER
Maytag HE2940S981 ELECTRIC WATER HEATER
Maytag HE2940S981CSA ELECTRIC WATER HEATER
Maytag HE2940SCSA ELECTRIC WATER HEATER
Maytag HE2940T ELECTRIC WATER HEATER
Maytag HE2940T981 ELECTRIC WATER HEATER
Maytag HE2940T981CSA ELECTRIC WATER HEATER
Maytag HE2940TCSA ELECTRIC WATER HEATER
Maytag HE2950S ELECTRIC WATER HEATER
Maytag HE2950S981 ELECTRIC WATER HEATER
Maytag HE2950S981CSA ELECTRIC WATER HEATER
Maytag HE2950SCSA ELECTRIC WATER HEATER
Maytag HE2950T ELECTRIC WATER HEATER
Maytag HE2950T981 ELECTRIC WATER HEATER
Maytag HE2950T981CSA ELECTRIC WATER HEATER
Maytag HE2950TCSA ELECTRIC WATER HEATER
Maytag HE2966T ELECTRIC WATER HEATER
Maytag HE2966T981 ELECTRIC WATER HEATER
Maytag HE2966T981CSA ELECTRIC WATER HEATER
Maytag HE2966TCSA ELECTRIC WATER HEATER
Amana HE2970 WASHER-TOP LOADING
Maytag HE2X30T961 ELECTRIC WATER HEATER
Maytag HE2X30T961CSA ELECTRIC WATER HEATER
Maytag HE2X40S961 ELECTRIC WATER HEATER
Maytag HE2X40S961CSA ELECTRIC WATER HEATER
Maytag HE2X50S961 ELECTRIC WATER HEATER
Maytag HE2X50S961CSA ELECTRIC WATER HEATER
Maytag HE2X50T961 ELECTRIC WATER HEATER
Maytag HE2X50T961CSA ELECTRIC WATER HEATER
Maytag HE2X82T961 ELECTRIC WATER HEATER
Maytag HE2X82T961CSA ELECTRIC WATER HEATER
Amana HE3003 WASHER-TOP LOADING
Amana HE3060 WASHER-TOP LOADING
Magic Chef HE309-2 HOOD
Magic Chef HE309-3 HOOD
Magic Chef HE309-4 HOOD
Magic Chef HE30A-1 HOOD
Magic Chef HE30A-1A HOOD
Magic Chef HE30E-400 HOOD
Maytag HE31230T ELECTRIC WATER HEATER
Maytag HE31230T961 ELECTRIC WATER HEATER
Maytag HE31230T961CSA ELECTRIC WATER HEATER
Maytag HE31230TCSA ELECTRIC WATER HEATER
Maytag HE31240S ELECTRIC WATER HEATER
Maytag HE31240S961 ELECTRIC WATER HEATER
Maytag HE31240S961CSA ELECTRIC WATER HEATER
Maytag HE31240SCSA ELECTRIC WATER HEATER
Maytag HE31250S ELECTRIC WATER HEATER
Maytag HE31250S961 ELECTRIC WATER HEATER
Maytag HE31250S961CSA ELECTRIC WATER HEATER
Maytag HE31250SCSA ELECTRIC WATER HEATER
Maytag HE31250T ELECTRIC WATER HEATER
Maytag HE31250T961 ELECTRIC WATER HEATER
Maytag HE31250T961CSA ELECTRIC WATER HEATER
Maytag HE31250TCSA ELECTRIC WATER HEATER
Maytag HE31282T ELECTRIC WATER HEATER
Maytag HE31282T961 ELECTRIC WATER HEATER
Maytag HE31282T961CSA ELECTRIC WATER HEATER
Maytag HE31282TCSA ELECTRIC WATER HEATER
Magic Chef HE369-2 HOOD
Magic Chef HE369-3 HOOD
Magic Chef HE369-4 HOOD
Maytag HE3830T981 ELECTRIC WATER HEATER
Maytag HE3830T981CSA ELECTRIC WATER HEATER
Maytag HE3840L960 ELECTRIC WATER HEATER
Maytag HE3840L960CSA ELECTRIC WATER HEATER
Maytag HE3840S981 ELECTRIC WATER HEATER
  #2 (permalink)
Old 12-14-2012, 01:57 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the compressor is very warm, but not vibrating, you probably have a bad ptc device, a square, plastic item with two, round compressor terminals and two input spade terminals. Measure across the two output terminals, if 5- 10 ohms, it's good, if blown open, replace it.
All ptc devices are not internally the same, so you must replace it with the exact one, or you risk compressor burnout.
I would try to get the correct one from the company that built it if you can't find a replacement from a supplier.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana not starting with new starter relay stewdog259 Refrigerator & Freezer Repair 0 09-13-2012 04:53 PM
Starter Relay Wiring exactorman Refrigerator & Freezer Repair 1 07-23-2011 06:35 AM
how to install new starter relay bigazbulldog Refrigerator & Freezer Repair 0 12-11-2010 09:16 AM
3-1 Universal Starter Relay tkwock Refrigerator & Freezer Repair 11 10-14-2010 02:33 AM
Starter relay tv guy Refrigerator & Freezer Repair 0 08-10-2007 01:08 PM
