| » Refrigerator Problem |
I ended up changing the cold control but I have noticed that the refrigerator has run for about 6 hours straight. It was a pretty easy install, is it possible that I did something wrong or is this normal? Maybe it could be the defrost timer???
As lons as you routed the sensing tubing from the control exactly were the old one was, you should be ok. If the fridg was warm, it takes up to 12 hrs to reach temperature.
__________________
The system is cycling on and off now but the refrigerator seems a lot colder than before. Previously to changing the cold control, I had the temperature setting at "3" out of a possible 1 to 5, I now have it set below "1" and the refrigerator still seems colder than it should be. It just seems to be running more than is needed.
I think the fridge should be around 45 degrees, it seems like the engine is running too hard. BTW i run a site on refrigerators, so I have some knowledge in the field
| Display Modes | |
| problem with refrigerator | gambri | Refrigerator & Freezer Repair | 3 | 04-06-2012 05:15 PM |
| Lg-Refrigerator Problem | gm8x60sman | Refrigerator & Freezer Repair | 0 | 12-13-2011 06:32 PM |
| Refrigerator Problem | duff1234 | Refrigerator & Freezer Repair | 1 | 09-02-2011 08:49 AM |
| Refrigerator Problem | FRED H | Refrigerator & Freezer Repair | 0 | 04-18-2011 12:55 PM |
| Refrigerator problem | Susan Leslie | Refrigerator & Freezer Repair | 1 | 05-17-2009 04:10 PM |
