Freezer side good. Fan runs. No thawing out of food. Fridge side about 48 degrees I think. I think it is probably the defrost timer (the diagram I have doesn't say that. It has Defrost Control on the right side next to the fresh food lamp and the defrost thermostat on the freezer side. I haven't heard it sizzle lately. The only thing I see that might be the defrost control is on the same panel as the temperature control on the right. It looks like a little hole like thing. I have no idea how to manually work it. I also don't know how to take a look at the coils. I know about removing the "back panel" but is that inside the fresh food side or freezer side; or is it the outside of the fridge on the back next to the wall? There was a little water on the floor under the unit when I moved it out from the wall. I appreciate your help.
Robbie
