Discuss
GE PDS18SBMBLBS Defrost issue
 in
Refrigerator & Freezer Repair
Background: I've never been thrilled with this fridge which is cheaply designed in many small ways. (I won't go into
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE PDS18SBMBLBS Defrost issue
  #1 (permalink)
Old 12-08-2012, 08:44 AM
Junior Member
ldavisfl is on a distinguished road
Default GE PDS18SBMBLBS Defrost issue
Model Number: PDS18SBMBLBS   Brand: GE   Age: More than 10 years
Background:
I've never been thrilled with this fridge which is cheaply designed in many small ways. (I won't go into that). But as an ME I hate to replace something I can fix. I have the freezer-cold/fridge-warm situation. I've done a bit of debugging but I need some advice on something.
When I uncovered the evaporator, the coils were clear. Yes there was very fine frost on the coils, but definitely not iced up.
What was odd to me was that the metal drain pan was totally clear, as if the defrost cycle did it's job.
The pan drains into a sump under the evap fan. The sump was full of frozen ice, level like a frozen pond. The lower blade was embedded in the ice. My first thought was that the drain was clogged, not letting the melted water out. The water refroze, stopped the fan, etc.
With a hair dryer and a couple cups of boiling water, the sump drained all at once. (Water poured of the tube exit in the back.) I convinced myself that the drain hose wasn't clogged at all. It appears totally open.
As part of my poking around, I did test continuity on the heater coil. It was fine. I did not check the thermostat or defrost timer. Like I said, the place where the frozen ice was was not near the defrost area. So I'm thinking the defrost cycle system is working. The evap fan works fine again, now that the blades are free.
I suppose it could be possible that a random object clogged the drain and I just "happened" to flush it out when I melted the ice. But I don't buy this.
Here's my big concern. The styrofoam to the right side of the sump was COMPLETELY waterlogged. The left was fine. Not sure why the difference. You can literally squeeze water out of it like a sponge. To me, this means that the material has failed and to replace it, unfortunately, means removing the evap because the foam extends under and around it. I am not willing to invest in this repair because I dislike this fridge anyway and it's 10 years old.
My concern is that this frozen ice in the failed styrofoam refreezes the melt water at the sump and blocks the drain. Is this a real possibility? Is it possible that this is not really an issue and I should just carry on, having unclogged the drain?
I ordered a new fridge last week (before my debug) and it arrives in 4 days. I could cancel the order, but having discovered this failed styrofoam I'm wondering if my current fridge isn't just plain shot.
Any advice?
Thanks,
LD
Ads By Google
Related Models
General Electric PDS18SBMBLBS Refrigerator
General Electric PDS18SBMBRBS Refrigerator
General Electric PDS18SBMCLBS Refrigerator
General Electric PDS18SBMCRBS Refrigerator
General Electric PDS18SBMLBS Refrigerator
General Electric PDS18SBMRBS Refrigerator
General Electric PDS20MBPABB Refrigerator
General Electric PDS20MBPACC Refrigerator
General Electric PDS20MBPAWW Refrigerator
General Electric PDS20MBRABB Refrigerator
General Electric PDS20MBRACC Refrigerator
General Electric PDS20MBRAWW Refrigerator
General Electric PDS20MBRBBB Refrigerator
General Electric PDS20MBRBCC Refrigerator
General Electric PDS20MBRBWW Refrigerator
General Electric PDS20MBSABB Refrigerator
General Electric PDS20MBSACC Refrigerator
General Electric PDS20MBSAWW Refrigerator
General Electric PDS20MBSBBB Refrigerator
General Electric PDS20MBSBCC Refrigerator
General Electric PDS20MBSBWW Refrigerator
General Electric PDS20MCPABB Refrigerator
General Electric PDS20MCPACC Refrigerator
General Electric PDS20MCPAWW Refrigerator
General Electric PDS20MCRABB Refrigerator
General Electric PDS20MCRACC Refrigerator
General Electric PDS20MCRAWW Refrigerator
General Electric PDS20MCRBBB Refrigerator
General Electric PDS20MCRBCC Refrigerator
General Electric PDS20MCRBWW Refrigerator
General Electric PDS20MFSABB Refrigerator
General Electric PDS20MFSACC Refrigerator
General Electric PDS20MFSAWW Refrigerator
General Electric PDS20MFSBBB Refrigerator
General Electric PDS20MFSBCC Refrigerator
General Electric PDS20MFSBWW Refrigerator
General Electric PDS20SBPALSS Refrigerator
General Electric PDS20SBPARSS Refrigerator
General Electric PDS20SBRALSS Refrigerator
General Electric PDS20SBRARSS Refrigerator
General Electric PDS20SBRBLSS Refrigerator
General Electric PDS20SBRBRSS Refrigerator
General Electric PDS20SBSALSS Refrigerator
General Electric PDS20SBSARSS Refrigerator
General Electric PDS20SBSBLSS Refrigerator
General Electric PDS20SBSBRSS Refrigerator
General Electric PDS20SCPALSS Refrigerator
General Electric PDS20SCPARSS Refrigerator
General Electric PDS20SCRALSS Refrigerator
General Electric PDS20SCRARSS Refrigerator
General Electric PDS20SCRBLSS Refrigerator
General Electric PDS20SCRBRSS Refrigerator
General Electric PDS20SFSALSS Refrigerator
General Electric PDS20SFSARSS Refrigerator
General Electric PDS20SFSBLSS Refrigerator
General Electric PDS20SFSBRSS Refrigerator
General Electric PDS21SBMABS Refrigerator
General Electric PDS22LBNABB Refrigerator
General Electric PDS22LBNABS Refrigerator
General Electric PDS22LBNACC Refrigerator
General Electric PDS22LBNAWW Refrigerator
Maytag PDS22LBNBB  Ref - Bottom Mounts
Maytag PDS22LBNCC  Ref - Bottom Mounts
Maytag PDS22LBNWW  Ref - Bottom Mounts
General Electric PDS22MBPABB Refrigerator
General Electric PDS22MBPACC Refrigerator
General Electric PDS22MBPAWW Refrigerator
General Electric PDS22MBRABB Refrigerator
General Electric PDS22MBRACC Refrigerator
General Electric PDS22MBRAWW Refrigerator
General Electric PDS22MBRBBB Refrigerator
General Electric PDS22MBRBCC Refrigerator
General Electric PDS22MBRBWW Refrigerator
General Electric PDS22MBSABB Refrigerator
General Electric PDS22MBSACC Refrigerator
General Electric PDS22MBSAWW Refrigerator
General Electric PDS22MBSBBB Refrigerator
General Electric PDS22MBSBCC Refrigerator
General Electric PDS22MBSBWW Refrigerator
General Electric PDS22MCPABB Refrigerator
General Electric PDS22MCPACC Refrigerator
General Electric PDS22MCPAWW Refrigerator
General Electric PDS22MCRABB Refrigerator
General Electric PDS22MCRACC Refrigerator
General Electric PDS22MCRAWW Refrigerator
General Electric PDS22MCRBBB Refrigerator
General Electric PDS22MCRBCC Refrigerator
General Electric PDS22MCRBWW Refrigerator
General Electric PDS22MFSABB Refrigerator
General Electric PDS22MFSACC Refrigerator
General Electric PDS22MFSAWW Refrigerator
General Electric PDS22MFSBBB Refrigerator
General Electric PDS22MFSBCC Refrigerator
General Electric PDS22MFSBWW Refrigerator
General Electric PDS22MHRABB Refrigerator
General Electric PDS22MHRACC Refrigerator
General Electric PDS22MHRAWW Refrigerator
General Electric PDS22MHRBBB Refrigerator
General Electric PDS22MHRBCC Refrigerator
General Electric PDS22MHRBWW Refrigerator
General Electric PDS22MISABB Refrigerator
General Electric PDS22MISACC Refrigerator
General Electric PDS22MISAWW Refrigerator
General Electric PDS22MISBBB Refrigerator
General Electric PDS22MISBCC Refrigerator
General Electric PDS22MISBWW Refrigerator
General Electric PDS22SBNBS
General Electric PDS22SBPALSS Refrigerator
General Electric PDS22SBPARSS Refrigerator
General Electric PDS22SBRALSS Refrigerator
General Electric PDS22SBRARSS Refrigerator
General Electric PDS22SBRBLSS Refrigerator
General Electric PDS22SBRBRSS Refrigerator
General Electric PDS22SBSALSS Refrigerator
General Electric PDS22SBSARSS Refrigerator
General Electric PDS22SBSBLSS Refrigerator
General Electric PDS22SBSBRSS Refrigerator
General Electric PDS22SCPALSS Refrigerator
General Electric PDS22SCPARSS Refrigerator
General Electric PDS22SCRALSS Refrigerator
  #2 (permalink)
Old 12-09-2012, 05:18 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
It would be best to add a drain heater to this,but would be difficult.
Lots of times, the drain will freeze up due to either the freezer is too cold, (should be around 5 degrees) or the condenser coils are clogged.
I would check both and turn the freezer control to a higher temp. if necessary.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Defrost Issue cmbicycles Refrigerator & Freezer Repair 1 08-16-2012 01:35 AM
GE Defrost issue philsmock Microwave Repair 0 03-15-2011 09:18 AM
Defrost Issue MATAKO Microwave Repair 0 01-12-2011 05:12 AM
GE, GBS22HCPAWW, Defrost issue ComposerChick Refrigerator & Freezer Repair 4 11-29-2010 03:50 PM
defrost issue askana Refrigerator & Freezer Repair 1 12-11-2008 11:11 AM
