Discuss
Compressor
 in
Refrigerator & Freezer Repair
Had a saltwater flood about eight inches. Refridge is warm both sides. Fan works good; lights come on. Checked compressor
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor
  #1 (permalink)
Old 12-07-2012, 05:29 AM
Junior Member
hardaway is on a distinguished road
Default Compressor
Model Number: MSD2274VEM   Brand: Maytag   Age: 1 - 5 years
Had a saltwater flood about eight inches. Refridge is warm both sides. Fan works good; lights come on. Checked compressor fine, changed startrelay combo. Compressor still will not start, clicks on and off. Removed Cntrl-Elec board salt water residue on it. Can that be the problem? Should I change that?
Ads By Google
Related Models
Maytag MSD2343ARA Ref - SXS/I&W
Maytag MSD2343ARQ Ref - SXS/I&W
Maytag MSD2343ARW Ref - SXS/I&W
Maytag MSD2351HEB Ref - SXS/I&W
Maytag MSD2351HEQ Ref - SXS/I&W
Maytag MSD2351HES Ref - SXS/I&W
Maytag MSD2351HEW Ref - SXS/I&W
Maytag MSD2351KES Ref - SXS/I&W
Maytag MSD2352KEB Ref - SXS/I&W
Maytag MSD2352KES Ref - SXS/I&W
Maytag MSD2352KEW Ref - SXS/I&W
Maytag MSD2354ARA Ref - SXS/I&W
Maytag MSD2354ARW Ref - SXS/I&W
Maytag MSD2354DRA Ref - SXS/I&W
Maytag MSD2354DRW Ref - SXS/I&W
Maytag MSD2354FRA Ref - SXS/I&W
Maytag MSD2354FRW Ref - SXS/I&W
Maytag MSD2355HEB Ref - SXS/I&W
Maytag MSD2355HEQ Ref - SXS/I&W
Maytag MSD2355HES Ref - SXS/I&W
Maytag MSD2355HEW Ref - SXS/I&W
Maytag MSD2356AEA Ref - SXS/I&W
Maytag MSD2356AEB Ref - SXS/I&W
Maytag MSD2356AEW Ref - SXS/I&W
Maytag MSD2357HEB Ref - SXS/I&W
Maytag MSD2357HEQ Ref - SXS/I&W
Maytag MSD2357HES Ref - SXS/I&W
Maytag MSD2357HEW Ref - SXS/I&W
Maytag MSD2359KEB Ref - SXS/I&W
Maytag MSD2359KEQ Ref - SXS/I&W
Maytag MSD2359KES Ref - SXS/I&W
Maytag MSD2359KEW Ref - SXS/I&W
Maytag MSD2422GRQ Ref - SXS/I&W
Maytag MSD2422GRW Ref - SXS/I&W
Maytag MSD2432GRQ Ref - SXS/I&W
Maytag MSD2432GRW Ref - SXS/I&W
Maytag MSD2433HEW Ref - SXS/I&W
Maytag MSD2434GEQ Ref - SXS/I&W
Maytag MSD2434GEW Ref - SXS/I&W
Maytag MSD2436GRQ Ref - SXS/I&W
Maytag MSD2436GRW Ref - SXS/I&W
Maytag MSD2445GRQ Ref - SXS/I&W
Maytag MSD2445GRW Ref - SXS/I&W
Maytag MSD2448DRQ Ref - SXS/I&W
Maytag MSD2448DRW Ref - SXS/I&W
Maytag MSD2454FRQ Ref - SXS/I&W
Maytag MSD2454FRW Ref - SXS/I&W
Maytag MSD2454GRQ Ref - SXS/I&W
Maytag MSD2454GRW Ref - SXS/I&W
Maytag MSD2456DEB Ref - SXS/I&W
Maytag MSD2456DEQ Ref - SXS/I&W
Maytag MSD2456DEW Ref - SXS/I&W
Maytag MSD2456GEB Ref - SXS/I&W
Maytag MSD2456GEQ Ref - SXS/I&W
Maytag MSD2456GEW Ref - SXS/I&W
Maytag MSD2458GEB Ref - SXS/I&W
Maytag MSD2458GEQ Ref - SXS/I&W
Maytag MSD2458GEW Ref - SXS/I&W
Maytag MSD2543ARA Ref - SXS/I&W
Maytag MSD2543ARW Ref - SXS/I&W
Maytag MSD2554ARA Ref - SXS/I&W
Maytag MSD2554ARW Ref - SXS/I&W
Maytag MSD2554DRA Ref - SXS/I&W
Maytag MSD2554DRW Ref - SXS/I&W
Maytag MSD2554FRA Ref - SXS/I&W
Maytag MSD2554FRW Ref - SXS/I&W
Maytag MSD2555DRA Ref - SXS/I&W
Maytag MSD2555DRW Ref - SXS/I&W
Maytag MSD2556AEA Ref - SXS/I&W
Maytag MSD2556AEB Ref - SXS/I&W
Maytag MSD2556AEW Ref - SXS/I&W
Maytag MSD2641KEB Ref - SXS/I&W
Maytag MSD2641KES Ref - SXS/I&W
Maytag MSD2641KEU Ref - SXS/I&W
Maytag MSD2641KEW Ref - SXS/I&W
Maytag MSD264RHEB Ref - SXS/I&W
Maytag MSD264RHEQ Ref - SXS/I&W
Maytag MSD264RHES Ref - SXS/I&W
Maytag MSD264RHEW Ref - SXS/I&W
Maytag MSD2650HEB Ref - SXS/I&W
Maytag MSD2650HEQ Ref - SXS/I&W
Maytag MSD2650HES Ref - SXS/I&W
Maytag MSD2650HEW Ref - SXS/I&W
Maytag MSD2650KES Ref - SXS/I&W
Maytag MSD2650KEU Ref - SXS/I&W
Maytag MSD2651HEB Ref - SXS/I&W
Maytag MSD2651HEQ Ref - SXS/I&W
Maytag MSD2651HES Ref - SXS/I&W
Maytag MSD2651HEW Ref - SXS/I&W
Maytag MSD2651KES Ref - SXS/I&W
Maytag MSD2651KEU Ref - SXS/I&W
Maytag MSD2651KGB Ref - SXS/I&W
Maytag MSD2651KGW Ref - SXS/I&W
Maytag MSD2652KEB Ref - SXS/I&W
Maytag MSD2652KES Ref - SXS/I&W
Maytag MSD2652KEU Ref - SXS/I&W
Maytag MSD2652KEW Ref - SXS/I&W
Maytag MSD2652KGB Ref - SXS/I&W
Maytag MSD2652KGW Ref - SXS/I&W
Maytag MSD2654FRQ Ref - SXS/I&W
Maytag MSD2654FRW Ref - SXS/I&W
Maytag MSD2654GRQ Ref - SXS/I&W
Maytag MSD2654GRW Ref - SXS/I&W
Maytag MSD2655HEB Ref - SXS/I&W
Maytag MSD2655HEQ Ref - SXS/I&W
Maytag MSD2655HES Ref - SXS/I&W
Maytag MSD2655HEW Ref - SXS/I&W
Maytag MSD2656DEB Ref - SXS/I&W
Maytag MSD2656DEQ Ref - SXS/I&W
Maytag MSD2656DEW Ref - SXS/I&W
Maytag MSD2656GEB Ref - SXS/I&W
Maytag MSD2656GEQ Ref - SXS/I&W
Maytag MSD2656GEW Ref - SXS/I&W
Maytag MSD2656KES Ref - SXS/I&W
Maytag MSD2656KEU Ref - SXS/I&W
Maytag MSD2656KGB Ref - SXS/I&W
Maytag MSD2656KGW Ref - SXS/I&W
Maytag MSD2657HEB Ref - SXS/I&W
Maytag MSD2657HEQ Ref - SXS/I&W
Maytag MSD2657HES Ref - SXS/I&W
  #2 (permalink)
Old 12-07-2012, 08:08 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You might have a bad wire splice from the salt water. Check the voltage to the compressor when it tries to start. If not 115 volts, that confirms it.
__________________
  #3 (permalink)
Old 12-07-2012, 11:54 AM
Junior Member
Default
how do you do that?
  #4 (permalink)
Old 12-07-2012, 01:10 PM
Senior Expert
APP Volunteer
Default
If the power spade terminals that go to the compressor start device are not insulated, just stick the probes there.
__________________
  #5 (permalink)
Old 12-07-2012, 06:39 PM
Junior Member
Default
Don't want to sound stupid, but I don't know what power spade terminals are. When I looked up the images I don't have connecters like that. I have 2 pieces that attach and plug directly into the compressor and a clip of wires that go into that.
  #6 (permalink)
Old 12-08-2012, 01:29 AM
Senior Expert
APP Volunteer
Default
What is the part number for the start device you replaced and is it the same as the old one?
__________________
  #7 (permalink)
Old 12-08-2012, 01:22 PM
Junior Member
Default
W10189190 and yes it is.
  #8 (permalink)
Old 12-09-2012, 01:54 AM
Senior Expert
APP Volunteer
Default
With the correct replacement part installed with the fridg power wires installed, and the fact the compressor will not start, but clicks off indicates the compressor is bad, probably due to hard starting current from the damaged start device.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compressor out? ToJo Refrigerator & Freezer Repair 1 02-11-2011 06:56 AM
freezer warm, clicking noise from compressor, compressor very hot sgtmajor58 Refrigerator & Freezer Repair 1 08-08-2009 06:57 PM
Compressor and Compressor Fan Not Working sdowns Refrigerator & Freezer Repair 0 05-02-2009 08:08 PM
Oil in compressor gregg Heating, Ventilation, and Air Conditioning (HVAC) 5 09-02-2008 08:50 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
