Discuss
Refrigerator fans intermittently run and stop
 in
Refrigerator & Freezer Repair
Refrigerator makes Temp. in freezer OK. Both condenser and evaporator fan kick on and off every few seconds, until temp
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator fans intermittently run and stop
  #1 (permalink)
Old 12-05-2012, 08:33 AM
Junior Member
pudroan is on a distinguished road
Default Refrigerator fans intermittently run and stop
Model Number: RT21LMXKQ01   Brand: Roper   Age: 1 - 5 years
Refrigerator makes Temp. in freezer OK. Both condenser and evaporator fan kick on and off every few seconds, until temp is made. Also compressor sometimes CLUNKS a little when starting and stoping, the motor mounts are OK. New Defrost timer (2213473)and Start device (2212964) and Condenser Fan has been installed. They seem to help a little, especially at first..
Ads By Google
Related Models
Roper RT21LMXKQ01 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKQ02 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKQ03 REFRIGERATOR
Roper RT21LMXKQ04 REFRIGERATOR
Whirlpool RT21LMXKQ05 REFRIGERATOR
Roper RT21LMXKQ06 REFRIGERATOR
Whirlpool RT21LMXKQ07
Roper RT21LMXKQ08 REFRIGERATOR
Roper RT21LMXKQ09 REFRIGERATOR
Roper RT21LMXKQ10 REFRIGERATOR
Roper RT21LMXKT00 REFRIGERATOR
Roper RT21LMXKT01 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKT02 TOP-MOUNT REFRIGERATOR
Roper RT21LMXKT03 REFRIGERATOR
Roper RT21LMXKT04 REFRIGERATOR
Whirlpool RT21LMXKT05 REFRIGERATOR
Roper RT21LMXKT06 REFRIGERATOR
Whirlpool RT21LMXKT07
Roper RT21LMXKT08 REFRIGERATOR
Roper RT21LMXKT09 REFRIGERATOR
Roper RT21LMXKT10 REFRIGERATOR
Roper RT21SKXJN00 REFRIGERATOR
Roper RT21SKXJW00 REFRIGERATOR
Roper RT21SKXLQ00 TOP-MOUNT REFRIGERATOR
Roper RT21SKXLQ01 TOP-MOUNT REFRIGERATOR
Roper RT21SKXLQ02 REFRIGERATOR
Roper RT22AKXBL00 REFRIGERATOR
Roper RT22AKXBW00 REFRIGERATOR
Roper RT25BKXAW00 Refrigerators*
Whirlpool RT25BKXZL01
Roper RT25BKXZW00 Refrigerators*
Roper RT25BKXZW01 Refrigerators*
Maytag RTC1500AAL REF - TOP MOUNT
Maytag RTC1500AAW REF - TOP MOUNT
Maytag RTC1500CAE REF - TOP MOUNT
Maytag RTC1500CAL REF - TOP MOUNT
Admiral RTC1500CGE REF - TOP MOUNT
Maytag RTC1500DAE REF - TOP MOUNT
Maytag RTC1500DAM REF - TOP MOUNT
Maytag RTC15A REF - TOP MOUNT
Maytag RTC1700AAL REF - TOP MOUNT
Maytag RTC1700AAW REF - TOP MOUNT
Maytag RTC1700CAE REF - TOP MOUNT
Maytag RTC1700CAL REF - TOP MOUNT
Maytag RTC1700DAE REF - TOP MOUNT
Maytag RTC1700DAM REF - TOP MOUNT
Maytag RTC17A REF - TOP MOUNT
Maytag RTC1900AAL REF - TOP MOUNT
Maytag RTC1900AAW REF - TOP MOUNT
Maytag RTC1900CAE REF - TOP MOUNT
Maytag RTC1900CAL REF - TOP MOUNT
Maytag RTC1900CAW REF - TOP MOUNT
Maytag RTC19A REF - TOP MOUNT
Admiral RTCA176AAE REF - TOP MOUNT
Admiral RTCA176AAM REF - TOP MOUNT
Admiral RTCA196AAE REF - TOP MOUNT
Admiral RTCA196AAM REF - TOP MOUNT
Admiral RTCA196BAE REF - TOP MOUNT
Admiral RTCA196BAM REF - TOP MOUNT
Admiral RTCA216AAE REF - TOP MOUNT
Admiral RTCA216AAM REF - TOP MOUNT
Admiral RTCA216BAE REF - TOP MOUNT
Admiral RTCA216BAM REF - TOP MOUNT
Maytag RTD1700AAL REF - TOP MOUNT
Maytag RTD1700AAW REF - TOP MOUNT
Maytag RTD1700CAE REF - TOP MOUNT
Maytag RTD1700CAL REF - TOP MOUNT
Maytag RTD1700CAW REF - TOP MOUNT
Maytag RTD1700CAW Ref - Top Mount
Admiral RTD1700CGE REF - TOP MOUNT
Admiral RTD1700CGL REF - TOP MOUNT
  #2 (permalink)
Old 12-05-2012, 08:43 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Connect a meter set to check VAC to the two wires on the new start device. If you have 120 VAC and the compressor is kicking off, you probably have a bad compressor.
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 12-05-2012, 11:20 AM
Junior Member
Default Bad compressor
The compressor and condenser fan recives power at the same time, as should be. I just caught the compressor not running with the condenser fan and it was pulling 10 amps enough to trip the overload and did while letting the fan run. The compressor was running at 3/4 amps in most cycles. So I guess I have a bad compressor, screwing up some of the time. Thanks so much for the follow up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge/freezer fans stop working peeples Refrigerator & Freezer Repair 2 09-04-2012 12:23 PM
refrigerator not cooling,fans run,warm air bharatibenhpatel Refrigerator & Freezer Repair 0 07-31-2011 10:30 AM
Refrigerator cools intermittently Unwind80 Refrigerator & Freezer Repair 6 06-23-2011 02:31 AM
Whirlpool Accubake - Fans won't stop & F2 E1 MentorWPOven Oven Repair (including Ranges and Cooktops) 1 01-21-2010 02:24 PM
Whirlpool Refrigerator works intermittently whtlght66 Refrigerator & Freezer Repair 1 02-09-2009 06:31 PM
