Discuss
Is the compressor dead?
 in
Refrigerator & Freezer Repair
I have a 2001 Kenmore 21' Bottom Mount Refrigerator (model # 596.71104101) (M14-71104) I woke up one morning to find
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Is the compressor dead?
  #1 (permalink)
Old 11-29-2012, 08:03 AM
Junior Member
enhouse3 is on a distinguished road
Default Is the compressor dead?
Model Number: 596.71104101   Brand: Kenmore   Age: More than 10 years
I woke up one morning to find everything in the freezer defrosted and mushy. The fridge compartment was also warm.
1. I checked the breaker and power to the unit. All checked out, there is power to the unit, the lights and fans are on.
2. Checked the cold control dial located in the freezer compartment. All checked out. Switch was set to "4" (same for in fridge compartment)
3. Tested the cold control to ensure fans turn off/on. All checked out fine. Fans in freezer/fridge and at the back for the condenser are on.
I did notice the compressor was not making any sound.
4. Checked the defrost timer. Advanced the dial for a click, (in to defrost mode) then click again (out of defrost mode) still no sound from compressor, fans did turn on when out of defrost mode. While I was checking the timer, I also cleaned out all the dust and dog hair from the condenser coil. Perfectly clean!
5 Listened to the defrost timer when I clicked it out of defrost mode. No ticking sound. I thought the timer may be bad, so replaced the defrost timer with new timer. Even with new timer, no compressor sound.
6. Opened back of freezer to have a look at evaporator coil and defrost heater. No frost, ice or water of any kind seen.
7. Checked defrost thermostat for continuity with multi meter. (tested with ice water) No continuity, so I replaced the defrost thermostat.
Still, no compressor sound.
8. while looking in the freezer, I noted the ice maker was corroded. Replaced ice maker unit. I had also noted earlier, before freezer failure, ice was
"hollow". At this time I also tested the water intake valve at the back of the unit. No continuity. I will replace the intake valve once I get the freezer working.
Also while in freezer, noted the door gasket was not making a good seal. Replaced the freezer door gasket.
Going back to the BACK of the unit. I noticed that there is a Supco 3 n' 1 start replay on the compressor. Checked online on how to test the starter and compressor for continuity and ground and ohm- this part confused me! I tried testing the C, S and R and windings etc... ugh....
Not sure. SO.... I replaced the Supco starter with a new one, just exactly as the old.
Still, no compressor operation. More looking online. Maybe the COLD CONTROL thermostat in the freezer is bad? If I understand correct, this part controls power to the compressor.
I have spend just over $300 on parts to try and get this fridge going. What am I missing? Do I just have a worm out compressor? Any suggestions and help? Thanks soooo much!
Ads By Google
Related Models
Kenmore 596.71104101  REFRIGERATOR
Kenmore 596.71109100  REFRIGERATOR
Kenmore 596.71109101  REFRIGERATOR
Kenmore 596.71142100  REFRIGERATOR
Kenmore 596.71142101  REFRIGERATOR
Kenmore 596.71144100  REFRIGERATOR
Kenmore 596.71144101  REFRIGERATOR
Kenmore 596.71162100  REFRIGERATOR
Kenmore 596.71162101  REFRIGERATOR
Kenmore 596.71164100  REFRIGERATOR
Kenmore 596.71164101  REFRIGERATOR
Kenmore 596.71272100  REFRIGERATOR
Kenmore 596.71272101  REFRIGERATOR
Kenmore 596.8590810  REFRIGERATOR
Kenmore 596.8590811  REFRIGERATOR
Kenmore 596.8590880  REFRIGERATOR
Kenmore 596.8590881  REFRIGERATOR
Kenmore 596.8590910  REFRIGERATOR
Kenmore 596.8590911  REFRIGERATOR
Kenmore 596.8590980  REFRIGERATOR
Kenmore 596.8590981  REFRIGERATOR
Kenmore 596.9500810  REFRIGERATOR
Kenmore 596.9500811  REFRIGERATOR
Kenmore 596.9500880  REFRIGERATOR
Kenmore 596.9500881  REFRIGERATOR
Kenmore 596.9500910  REFRIGERATOR
Kenmore 596.9500911  REFRIGERATOR
Kenmore 596.95308200  Side-by-Side
Kenmore 596.95308500  Side-by-Side
Kenmore 596.95308800  Side-by-Side
Kenmore 596.9535610  Side-by-Side
Kenmore 596.9535611  REFRIGERATOR
Kenmore 596.9535650  Side-by-Side
Kenmore 596.9535651  REFRIGERATOR
Kenmore 596.9535680  Side-by-Side
Kenmore 596.9535681  REFRIGERATOR
Kenmore 596.95508200  REFRIGERATOR
Kenmore 596.95508500  REFRIGERATOR
Kenmore 596.95508800  REFRIGERATOR
Kenmore 596.95508900  REFRIGERATOR
Kenmore 596.9555510  SIDE BY SIDE REFRIGERATOR
Kenmore 596.9555550  SIDE BY SIDE REFRIGERATOR
Kenmore 596.9555580  SIDE BY SIDE REFRIGERATOR
Kenmore 59652672201 KENMORE REFRIGERATOR
Kenmore 59652673201 KENMORE REFRIGERATOR
Kenmore 59652674201 KENMORE REFRIGERATOR
Kenmore 59652679201 KENMORE REFRIGERATOR
Kenmore 59653462301 KENMORE REFRIGERATOR
Kenmore 59653463301 KENMORE REFRIGERATOR
Kenmore 59653464301 KENMORE REFRIGERATOR
Kenmore 59653469301 KENMORE REFRIGERATOR
Kenmore 59657582790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657582791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657585790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657585791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657587790 SIDE BY SIDE REFRIGERATOR
Kenmore 59657587791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658392890 Side-by-Side
Kenmore 59658395890 Side-by-Side
Kenmore 59658397890 Side-by-Side
Kenmore 59658622990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658627990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658632890 Side-by-Side
Kenmore 59658635890 Side-by-Side
Kenmore 59658637890 Side-by-Side
Kenmore 59658642890 Side-by-Side
Kenmore 59658642891 REFRIGERATOR
Kenmore 59658644000 REFRIGERATOR
Kenmore 59658647890 Side-by-Side
Kenmore 59658692890 Side-by-Side
Kenmore 59658695890 Side-by-Side
Kenmore 59658697890 Side-by-Side
Kenmore 59662212200 KENMORE REFRIGERATOR
Kenmore 59662213200 KENMORE REFRIGERATOR
Kenmore 59662214200 KENMORE REFRIGERATOR
Kenmore 59662219200 KENMORE REFRIGERATOR
Kenmore 59662222200 REFRIGERATOR
Kenmore 59662224200 REFRIGERATOR
Kenmore 59662232200 REFRIGERATOR
Kenmore 59662234200 REFRIGERATOR
Kenmore 59662239200 REFRIGERATOR
Kenmore 59662822200 KENMORE REFRIGERATION
Kenmore 59662824200 KENMORE REFRIGERATION
Kenmore 59662832200 KENMORE REFRIGERATION
Kenmore 59662834200 KENMORE REFRIGERATION
Kenmore 59662839200 KENMORE REFRIGERATION
Kenmore 59662842100 REFRIGERATOR
Kenmore 59662842101 REFRIGERATOR
Kenmore 59662844100 REFRIGERATOR
Kenmore 59662844101 REFRIGERATOR
Kenmore 59662912200 KENMORE REFRIGERATION
Kenmore 59662913200 KENMORE REFRIGERATION
Kenmore 59662914200 KENMORE REFRIGERATION
Kenmore 59662919200 KENMORE REFRIGERATION
Kenmore 59663222200 KENMORE REFRIGERATION
Kenmore 59663224200 KENMORE REFRIGERATION
Kenmore 59663822200 KENMORE REFRIGERATION
Kenmore 59663824200 KENMORE REFRIGERATION
Kenmore 59667272790 22 BOTTOM-MOUNT REFRIGERATOR
Kenmore 59667275790 22 BOTTOM-MOUNT REFRIGERATOR
Kenmore 59667277790 22 BOTTOM-MOUNT REFRIGERATOR
Kenmore 59668142790 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59668142791 21 BOTTOM FREEZER REFRIGERATOR
Kenmore 59668142890 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59668142891 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59668147790 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59668147791 21 BOTTOM FREEZER REFRIGERATOR
Kenmore 59668147890 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59668147891 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59669142990 21 BOTTOM FREEZER REFRIGERATOR
Kenmore 59669142991 BOTTOM MOUNT REFRIGERATOR
Kenmore 59669142992 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59669144000 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59669147990 21 BOTTOM FREEZER REFRIGERATOR
Kenmore 59669147991 BOTTOM MOUNT REFRIGERATOR
Kenmore 59669147992 BOTTOM MOUNT
Kenmore 59669162990 BOTTOM MOUNT
Kenmore 59669162991 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59669164000 21" BOTTOM FREEZER REFRIGERATOR
Kenmore 59669167990 BOTTOM MOUNT
  #2 (permalink)
Old 11-29-2012, 09:26 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Remove the start devise from the compressor. Using the multimeter check continuity between three compressor's pins and between any of this pins and ground.
You should have continuity between pins and no continuity to the ground.
If the reading is incorrect - you have a bad compressor.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-29-2012, 10:17 AM
Junior Member
Default
Thanks Simon. I have set my multimeter to "sound" with continuity.
From C to R no sound. From C to S no sound. From S to R sound.
For ground, C to the compressor its self (with some of the paint scratched off to reveal metal) no sound. From R to the compressor sound and from S to compressor sound.
Do I also need to remove the green ground wire from the compressor, in addition to the 3 n' 1?
Looks like I have a dead compressor.
  #4 (permalink)
Old 11-29-2012, 03:34 PM
Expert
Default
Hi.
You are right - it's bad compressor.
Simon.
__________________
  #5 (permalink)
Old 11-30-2012, 02:01 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
3 n 1 blew out the compressor windings, have seen this often. Lesson learned, Never use a 3 n 1 hard start on a domestic, fractional hp compressor.
__________________
  #6 (permalink)
Old 11-30-2012, 07:13 AM
Junior Member
Default
Thank you richappy. I figured that is what did it. The 3 n 1 was there when I in inherited the fridge. I worked great for 4+ years. ugh.
Given what I have already invested to try and get it going, do you think it is worth the money to put in a new compressor with factory start/relay/ovrload?
I have about $300 into it now. I LOVE the fridge. Bottom freezers and great for our family.
Looks like on this site, a compressor kit for my model will run $200-$350. They I would need to find a tech to install. Given the cost of a new fridge with bottom freezer and what I already have into repairs for the one I have, would you suggest I replace the compressor?
  #7 (permalink)
Old 11-30-2012, 08:06 AM
Junior Member
Default
Thank you Simon. Given what I have into the unit now, about $300. Do you think it is worth it to put in a new compressor? They go for $2-300 on this website, plus what a tech would charge to install. Suggestions?
I love this fridge. Bottom freezer works great for our family
  #8 (permalink)
Old 11-30-2012, 09:49 AM
Senior Expert
APP Volunteer
Default
You have burnout contamination. You can check servicers,but common charge us $600- 800
__________________
  #9 (permalink)
Old 11-30-2012, 09:52 AM
Junior Member
Default
grumble grumble. Sad. seems like a waste of materials that will now go to a landfill or something. I guess I will remove all the parts I installed that are new.
I really appreciate all the help. Thank you!
  #10 (permalink)
Old 11-30-2012, 11:49 AM
Expert
Default
My suggestion is also to get another fridge.
If the parts you recently replaced where purchased from APP contact our customer service for the return policy.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help- GE Fridge is dead - compressor? Dhilb Refrigerator & Freezer Repair 15 01-29-2013 07:18 AM
Is It Dead? Compressor Runs, Walls Stay Warm aavgerinos Refrigerator & Freezer Repair 5 08-30-2010 07:51 AM
samsung fridge dead....compressor? evilstevie Refrigerator & Freezer Repair 0 02-26-2010 11:04 PM
freezer warm, clicking noise from compressor, compressor very hot sgtmajor58 Refrigerator & Freezer Repair 1 08-08-2009 06:57 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
