Discuss
Freezer good Fridge too warm
 in
Refrigerator & Freezer Repair
My side by side freezer is working fine but the fresh food section is not holding temp. I took the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer good Fridge too warm
  #1 (permalink)
Old 11-28-2012, 06:57 PM
Junior Member
laak01 is on a distinguished road
Default Freezer good Fridge too warm
Brand: Frigidaire   Age: 5 - 10 years
My side by side freezer is working fine but the fresh food section is not holding temp. I took the evap fan housing off the cabinet and in the process it started working. I put it back and now it will work until it reaches temp, then it turns off, but on the next cycle on it will not blow...at this point if I tap or bump the housing it will make almost a timer sound for a few seconds and then kick on...any suggestions?
Ads By Google
  #2 (permalink)
Old 11-29-2012, 03:26 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I would replace the fan.
__________________
  #3 (permalink)
Old 11-29-2012, 04:19 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Your back panel might be jaming the fan blade. I would keep the panel off temporarily and see if it works reliably. If not, remove the motor. If a 115 volt motor, stick it in the wall outlet. If it then still fails, replace the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is Too Warm, Fridge is Good AmandaKenmore Refrigerator & Freezer Repair 1 01-26-2011 02:31 PM
Frididaire side by side freezer good, warm fridge gyuhr Refrigerator & Freezer Repair 5 08-30-2010 12:45 PM
Freezer is good refrig too warm at top vernonpayne Refrigerator & Freezer Repair 0 09-10-2009 08:36 AM
Freezer is good refrig warm vernonpayne Refrigerator & Freezer Repair 0 09-08-2009 08:30 AM
freezer good and frig warm hectorj134 Refrigerator & Freezer Repair 0 09-05-2008 04:35 AM
