Discuss
Kenmore - Freezer Cold / Fridge warm
 in
Refrigerator & Freezer Repair
I have a Kenmore Model: 795.65002402 (made by LG with the 795 prefix, I presume), bottom freezer. Symptoms : Everything
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore - Freezer Cold / Fridge warm
  #1 (permalink)
Old 09-26-2009, 06:22 PM
Junior Member
Rush2112 is on a distinguished road
Default Kenmore - Freezer Cold / Fridge warm
Model Number: 795.65002402   Brand: Kenmore   Age: 1 - 5 years
Symptoms:
Everything works fine on the default fridge / freezer settings set on 4 and 4. Approximately 24 hours after operation it will trigger a "Poor of Defrost" [sic] with the error code 5-6-7 LEDs lit on the freezer control panel.
If it's allowed to operate any much longer than that, the fridge will stop getting cool air and start warming up. The freezer will remain cold with no apparent issues.
While the fridge is operating fine, the temp is about 38 F.
Pulling the back panel off the freezer portion shows light frost evenly on the evaporator coils.
No other faults indicated.
Troubleshooting:
The Failure Diagnosis table states (verbatim):
Contents: 2hours later After starting defrost, If sensor doesn't be over 46 F (8 C).
Remarks: Snapping of defrost heater or Temperature fuse, pull-out of Connector (indicated minimum 2 Hours after failure occurs)
OK, whatever the heck that means -- I think I need a translator to translate the translation.
- Ran Test 1 and Test 2, no apparent errors indicated. Though it's hard to be certain, because the Technical Data manual has great sentences like this: "It reset if you do again as clause."
- Tested the defrost heater and it read 36 Ohms
- Fan from the freezer to the fridge (by the evaporator) is operating and blowing air into the top.
- After letting the unit sit for 24 hours, it repeats the same behavior as stated in the "Symptoms" section of this post.
- Unplugging and plugging the unit back in after the error code will reset the controls back to the default settings, but the error code will come back after a short time.
I read through a ton of posts and was able to get this far. Hopefully someone might have an idea on what to check next.
Thanks,
Rush
Related Models
Kenmore 79531002700 REFRIGERATOR
Kenmore 79531006700 REFRIGERATOR
Kenmore 79539113600 SIDE-BY-SIDE
Kenmore 79551012010 REFRIGERATOR
Kenmore 79551012011 REFRIGERATOR
Kenmore 79551012012 REFRIGERATOR
Kenmore 79551013010 REFRIGERATOR
Kenmore 79551013011 REFRIGERATOR
Kenmore 79551013012 REFRIGERATOR
Kenmore 79551014010 REFRIGERATOR
Kenmore 79551014011 REFRIGERATOR
Kenmore 79551014012 REFRIGERATOR
Kenmore 79551016010 REFRIGERATOR
Kenmore 79551016011 REFRIGERATOR
Kenmore 79551016012 REFRIGERATOR
Kenmore 79551019010 REFRIGERATOR
Kenmore 79551019011 REFRIGERATOR
Kenmore 79551019012 REFRIGERATOR
Kenmore 79551022010 REFRIGERATOR
Kenmore 79551022011 REFRIGERATOR
Kenmore 79551022012 REFRIGERATOR
Kenmore 79551023010 REFRIGERATOR
Kenmore 79551023011 REFRIGERATOR
Kenmore 79551023012 REFRIGERATOR
Kenmore 79551024010 REFRIGERATOR
Kenmore 79551024011 REFRIGERATOR
Kenmore 79551024012 REFRIGERATOR
Kenmore 79551026010 REFRIGERATOR
Kenmore 79551026011 REFRIGERATOR
Kenmore 79551026012 REFRIGERATOR
Kenmore 79551029010 REFRIGERATOR
Kenmore 79551029011 REFRIGERATOR
Kenmore 79551029012 REFRIGERATOR
Kenmore 79551032010 REFRIGERATOR
Kenmore 79551032011 REFRIGERATOR
Kenmore 79551033010 REFRIGERATOR
Kenmore 79551033011 REFRIGERATOR
Kenmore 79551034010 REFRIGERATOR
Kenmore 79551034011 REFRIGERATOR
Kenmore 79551036010 REFRIGERATOR
Kenmore 79551036011 REFRIGERATOR
Kenmore 79551039010 REFRIGERATOR
Kenmore 79551039011 REFRIGERATOR
Kenmore 79551072010 REFRIGERATOR
Kenmore 79551072011 REFRIGERATOR
Kenmore 79551073010 REFRIGERATOR
Kenmore 79551073011 REFRIGERATOR
Kenmore 79551074010 REFRIGERATOR
Kenmore 79551074011 REFRIGERATOR
Kenmore 79551076010 REFRIGERATOR
Kenmore 79551076011 REFRIGERATOR
Kenmore 79551079010 REFRIGERATOR
Kenmore 79551079011 REFRIGERATOR
Kenmore 79551082010 REFRIGERATOR
Kenmore 79551082011 REFRIGERATOR
Kenmore 79551083010 REFRIGERATOR
Kenmore 79551083011 REFRIGERATOR
Kenmore 79551086010 REFRIGERATOR
Kenmore 79551086011 REFRIGERATOR
Kenmore 79551089010 REFRIGERATOR
Kenmore 79551089011 REFRIGERATOR
Kenmore 79551092010 REFRIGERATOR
Kenmore 79551092011 REFRIGERATOR
Kenmore 79551093010 REFRIGERATOR
Kenmore 79551093011 REFRIGERATOR
Kenmore 79551099010 REFRIGERATOR
Kenmore 79551099011 REFRIGERATOR
Kenmore 79551312010 REFRIGERATOR
Kenmore 79551312011 REFRIGERATOR
Kenmore 79551312012 REFRIGERATOR
Kenmore 79551313010 REFRIGERATOR
Kenmore 79551313011 REFRIGERATOR
Kenmore 79551313012 REFRIGERATOR
Kenmore 79551314010 REFRIGERATOR
Kenmore 79551314011 REFRIGERATOR
Kenmore 79551314012 REFRIGERATOR
Kenmore 79551316010 REFRIGERATOR
Kenmore 79551316011 REFRIGERATOR
Kenmore 79551316012 REFRIGERATOR
Kenmore 79551319010 REFRIGERATOR
Kenmore 79551319011 REFRIGERATOR
Kenmore 79551319012 REFRIGERATOR
Kenmore 79551322010 REFRIGERATOR
Kenmore 79551322011 REFRIGERATOR
Kenmore 79551322012 REFRIGERATOR
Kenmore 79551323010 REFRIGERATOR
Kenmore 79551323011 REFRIGERATOR
Kenmore 79551326010 REFRIGERATOR
Kenmore 79551326011 REFRIGERATOR
Kenmore 79551329010 REFRIGERATOR
Kenmore 79551329011 REFRIGERATOR
Kenmore 79551329012 REFRIGERATOR
Kenmore 79551372010 REFRIGERATOR
Kenmore 79551373010 REFRIGERATOR
Kenmore 79551374010 REFRIGERATOR
Kenmore 79551376010 REFRIGERATOR
Kenmore 79551379010 REFRIGERATOR
Kenmore 79558812900 REFRIGERATOR
Kenmore 79558813900 REFRIGERATOR
Kenmore 79558814900 REFRIGERATOR
Kenmore 79558814901 REFRIGERATOR
Kenmore 79558816900 REFRIGERATOR
Kenmore 79558819900 REFRIGERATOR
Kenmore 79558819901 REFRIGERATOR
Kenmore 79558822900 REFRIGERATOR
Kenmore 79558823900 REFRIGERATOR
Kenmore 79558826900 REFRIGERATOR
Kenmore 79558829900 REFRIGERATOR
Kenmore 79565002400 REFRIGERATOR
Kenmore 79565002401 BOTTOM-MOUNT
Kenmore 79565002402 BOTTOM-MOUNT REFRIGERATOR
Kenmore 79565004400 REFRIGERATOR
Kenmore 79565004401 BOTTOM-MOUNT
Kenmore 79565004402 REFRIGERATOR
Kenmore 79565009400 REFRIGERATOR
Kenmore 79565009401 BOTTOM-MOUNT
Kenmore 79565012400 REFRIGERATOR
Kenmore 79565012401 BOTTOM-MOUNT
Kenmore 79565014400 REFRIGERATOR
Kenmore 79565014401 BOTTOM-MOUNT
  #2 (permalink)
Old 09-30-2009, 08:37 AM
Junior Member
Default An update...
After looking around a little bit more, I think I might have found a problem.
There is a defrost control assembly next to the evaporator coils just above the defrost heater that I took and and tested.
Image link here
It looks like the red and brown wire go through a 10 amp fusible link. When checking continuity between the red and the brown wire, it indicates an open with an infinite Ohms reading.
When checking continuity between the two orange wires, it shows a 15.1K Ohm reading at room temp. and around 50.0K Ohm reading at freezer temp.
Just curious if anyone has had any experience with this part. On the surface it would appear defective (open between the red and brown), but would like get a second opinion.
Thanks,
Rush
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge cold but freezer is warm mkthrush Refrigerator & Freezer Repair 0 09-15-2009 01:04 PM
freezer cold fridge warm tkincaid027 Refrigerator & Freezer Repair 1 06-04-2009 05:43 PM
Fridge warm, freezer cold angiebaaaby Refrigerator & Freezer Repair 8 11-19-2008 08:46 PM
Freezer cold/Fridge Warm ssines Refrigerator & Freezer Repair 1 01-08-2008 09:23 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
