| » ice maker no water |
Model Number: 79572053110 Brand: Kenmore Age: 1 - 5 years
My Kenmore (LG) Elite doesn't have water going to the ice maker. The water through the door is fine. I replaced the ice maker module because I thought it wasn't rotating. I found the manual switch and the tray rotates. I hear what I think is the water valve come on and stop after a reasonable time, but no water in the tray. I put water in the tray and it froze and ejected the ice. I don't see any leaking water laying around. Could the tube to the tray have iced up? This is the bottom freezer, French door, 31 cu foot model. Thank you in advance, Jim.
Check the water valve behind the machine. It may have a bad solenoid. Here's the one you need: LG AJU72992603 Valve Assembly,water - AppliancePartsPros.com
__________________
Ricks Appliance Repair |
Thank you for your reply. I pulled it out and saw the valve. It only has one tube going into the interior. I went to the spot where the tube goes in and a tube comes out going to the ice maker(?). I disconnected the tube going to ice maker and pressed the cycle button on the ice tray. Water came out (2/3 cup) I put the tye wrap up the tube also. I took the ice maker assy. out and looked at the water tube. It looked red inside. I inserted a 10" plastic tye wrap in and got a couple of drops of water. I reassy. and pushed the cycle buttom - cycled but no water. Any thoughts on what to do now?
Best regards, Jim. |
I HAVE water at the door. I HAVE water coming out the back going to the ice maker tube. I don't have water at what I think is the other end of that tube. What's between the tube in top right corner of the back and the ice maker tray tube? Regards. Jim.
Quote:
Jim, most refrigerators use a dual coil water valve. I do remember seeing an LG that used only a single coil water valve. Is yours the single coil?
__________________
| Display Modes | |
| Can You adjust water flow for Maytag ice maker #95109-1. ( Older ice maker) | 11charm34 | Refrigerator & Freezer Repair | 0 | 09-02-2012 11:49 AM |
| Kenmore Ice Maker --no ice--maker or water control valve | cps.extra | Refrigerator & Freezer Repair | 0 | 08-13-2011 08:59 AM |
| New ice maker installed but no water running to ice maker | corona32guiness | Refrigerator & Freezer Repair | 0 | 01-06-2010 05:14 PM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:27 AM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:20 AM |
