Discuss
GE Monogram Side by Side "Lava" Ice
 in
Refrigerator & Freezer Repair
Hello, I have a 42" GE Monogram side by side first installed in 1999. It has been having issues with
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Monogram Side by Side "Lava" Ice
  #1 (permalink)
Old 11-19-2012, 12:27 PM
Junior Member
edonlon is on a distinguished road
Default GE Monogram Side by Side "Lava" Ice
Brand: GE   Age: More than 10 years
Hello,
I have a 42" GE Monogram side by side first installed in 1999. It has been having issues with ice build up in the freezer compartment for the last few months. I have tried defrosting the unit and the problem comes back. Last time I took the inside top of the freezer apart and completely cleaned out the drain tube (I removed the evaporator drain pan) so I know it isn't clogged with lint, dust, etc. I was good for several weeks, but this morning I see the signs of the ice returning. I have seen reference to an "Icing Kit". Is this simply a replacement part for my original parts or is there something really different that addresses the underlying issue. I'm sure it is possible that my defrost heater is simply wearing out. Any suggestions would be appreciated. Thanks.
Ads By Google
  #2 (permalink)
Old 11-20-2012, 09:38 PM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
One of the components in the defrost system is out. Use an ohmmeter to check the defrost heater and defrost thermostat for continuity. Check the defrost thermostat first while it's frosty. It needs to be below 40*F to show continuity. If both check good, replace the motherboard.
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 11-21-2012, 08:22 AM
Junior Member
Default
Thanks for your reply Rick. I will give it a try over the weekend. I'm not sure I see a motherboard in the parts lists that I have seen online. The only one showing up seems to be related to the dispenser. I am fairly confident the timer is working as when I rotate it manually, it clicks and turns off the system so it can complete the defrost cycle. I did not notice the thermostat during my last tear down, but will look for it and measure the resistance when it is apart for debug.
  #4 (permalink)
Old 11-21-2012, 08:56 AM
Expert
APP Volunteer
Default
If you have a defrost timer then you don't have a motherboard (no model number)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Monogram 48" side by side Fridge water leak jcoukos Refrigerator & Freezer Repair 4 Yesterday 06:43 AM
Side by side handle lose, need "know how" JSKnox11 Refrigerator & Freezer Repair 4 12-07-2012 01:11 AM
Lg Side By Side Error "co" Display EVERAM Refrigerator & Freezer Repair 0 09-30-2010 05:18 AM
Hotpoint Side-by Side Not "dispensing ice and water" butch.bartlett Refrigerator & Freezer Repair 0 01-12-2010 09:06 PM
GE side-by-side refrigerator/freezer (Model #:GSS25WGPE WW) with "whirring" noise TAR2 Refrigerator & Freezer Repair 0 11-22-2009 08:32 AM
