| » GE TBX18kjb not freezer not freezing |
Model Number: TBX18kjb Brand: GE Age: More than 10 years
Freezer not getting below 38 and fridge cooling to 40 only. Fridge stored for eight months. Worked great before that. Vacuumed coils when we moved it. ANy ideas?
Hi.
Check if the condenser fan motor is running. Then open the evaporator cover (in the freezer) and check how the evaporator is covered with frost. If it's only small area is frosted then there is a sealed system problem which is probably more expensive than replacement refrigerator. Here are the breakdown diagrams and http://www.appliancepartspros.com/ca...-tbx18kjb.html Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks Simon,
I removed the back of the freezer compartment and the right hand four inches was frozen over. I defrosted it and let it set for an hour. Started it back up and I have 3-4 inches of the coils on the right hand side frosting up now. Are you saying that there is no repair or that it is just too costly? Thanks again. |
Yes, there is the sealed system problem and that is costly.
You need to call a pro. Simon.
__________________
Check the nameplate, if the refrigerant is R12, the system can be re-charged with R414B and the system can be checked for leaks, total cost should be less than $100. Might not be worth it as the new units are much more efficient.
__________________
| Display Modes | |
| Amana fridge w/btm freezer - freezer not freezing, fans running | JonnyB | Refrigerator & Freezer Repair | 5 | 07-30-2012 10:58 AM |
| Fridge freezing, Freezer over-freezing | breistl77 | Refrigerator & Freezer Repair | 0 | 12-29-2009 09:12 AM |
| GE - fridge freezing in drawers, freezer not freezing at top, but coils frozen over | jaxcarlson | Refrigerator & Freezer Repair | 0 | 12-01-2009 09:42 AM |
| GE fridge/freezer freezer is defrosting and not freezing anymore | booomer | Refrigerator & Freezer Repair | 1 | 04-06-2009 05:32 AM |
| Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up | badace | Refrigerator & Freezer Repair | 1 | 12-02-2007 09:54 AM |
