| » refrigerator freezing food |
Model Number: FRT18TPHWO Brand: Frigidaire Age: More than 10 years
The refrigerator is freezing food in the fridge compartment with the control on 1. I have replaced the defrost timer and the temp control was replaced a few years ago. My son in law replaced the thermostat a couple years ago. I have checked the temp control and it seems to be working properly. I used an ohm meter to check it. I then placed the temp control in a working freezer and it had the correct reading. Any suggestions?
Parts for Frigidaire FRT18TPHW0 Refrigerator - AppliancePartsPros.com I have replaced the defrost timer A defrost problem would have caused the fresh food section to be too warm. and the temp control was replaced a few years ago. My son in law replaced the thermostat a couple years ago. I am assuming both the above are referring to the main temperature control thermostat I have checked the temp control and it seems to be working properly. I used an ohm meter to check it. I then placed the temp control in a working freezer and it had the correct reading. I am not sure how you did the test or how you determined it was OK. Check that the evaporator/freezer fan is running. It should be on whenever the compressor is on. It is required for proper air circulation in the unit. I am assuming that the compressor is cycling normally (not on all the time) though it may run longer than it used to. Odds are that it is a main thermostat problem.
__________________
Hi.
Adjust the air flow from the freezer to a minimum if possible.If still will be too cold - replace the cold control Part number: 5304404821 Here are the breakdown diagrams and Shelves parts for Frigidaire FRT18TPHW0 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Refrigerator is freezing food in the fresh food compartment | KodiakJim37762 | Refrigerator & Freezer Repair | 1 | 05-24-2012 11:17 AM |
| refrigerator is freezing food | uptomealso | Refrigerator & Freezer Repair | 1 | 10-03-2011 02:20 AM |
| refrigerator freezing food | brookeshank | Refrigerator & Freezer Repair | 0 | 05-31-2011 12:00 PM |
| Freezing food in refrigerator | tjinholly | Refrigerator & Freezer Repair | 0 | 04-21-2011 02:19 PM |
| refrigerator freezing food | nanj2911 | Refrigerator & Freezer Repair | 1 | 07-17-2009 07:02 PM |
