| » GE refrig not cold enough |
Push the damper half way closed and unplug the refrigerator to reset the motherboard. Set the temperature controls at 5 and 5 and restore power. The damper door should move immediately after restoring power. You have ten seconds to check it. If the damper door moves, verify the thermistor(s) is within range. (16.3K ohms at 32*F). If the thermistor(s) resistance is within range, replace the motherboard. If the damper door does not move when power is restored, disconnect the harness connector at the damper and use an ohmmeter to measure the resistance between the yellow and red/black wires and between the white/brown and blue/yellow wires. Your meter should show 420 ohms for both readings. If not, replace the damper. If the ohms are correct, disconnect the J3 connector on the motherboard and unplug the machine. Restore power to the machine. Check for 6 VDC between J4 Pin3 (Common) and each of the pins J3-1, J3-2, J3-3 and J3-4. If the VDC in not correct, replace the motherboard.
__________________
Ricks Appliance Repair |
__________________
| Display Modes | |
| Outside Refrig/Freezer in Garage does not stay cold in cold weather | verno1 | Refrigerator & Freezer Repair | 2 | 12-14-2010 12:07 PM |
| Jenn-Air refrig too cold | MaineAlan | Refrigerator & Freezer Repair | 2 | 09-14-2010 05:29 AM |
| Refrig. too cold. Freezer not cold enough | dan1520 | Refrigerator & Freezer Repair | 0 | 08-31-2010 06:25 AM |
| Refrig not cold | bwall117 | Refrigerator & Freezer Repair | 7 | 04-13-2008 04:40 PM |
| Refrig not cold | bc1 | Refrigerator & Freezer Repair | 0 | 11-06-2007 02:01 PM |
