Discuss
jwatki11
 in
Refrigerator & Freezer Repair
Hello everyone, I am new to the board and hope to get to know everyone in the future. I am
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » jwatki11
  #1 (permalink)
Old 11-18-2012, 08:48 AM
Junior Member
jwatki11 is on a distinguished road
Default refrigerator not defrosting
Model Number: srde27s3e   Brand: Amana   Age: More than 10 years
Hello everyone, I am new to the board and hope to get to know everyone in the future. I am posting to get help on a 1996 amana side by side refrigerator, part# srde27s3e. About a week ago the hi temp alarm went off, the fridge was at 55 degrees, and water was leaking out of freezer door.
I determined the evaporator coil was frozen, defrosted unit, ran fine for a few days and now the coil is starting to freeze again. tried to put it in defrost mode by pressing the door switch four times in six seconds, nothing. If it is the ADC, thermostat or defrost heater, what would be the best way to access these components.
Thank you
Ads By Google
Related Models
Amana SRDE27S3E Ref - SXS/I&W
Amana SRDE27S3L Ref - SXS/I&W
Amana SRDE27S3W Ref - SXS/I&W
Amana SRDE27TPE Ref - SXS/I&W
Amana SRDE27TPSE Ref - SXS/I&W
Amana SRDE27TPW Ref - SXS/I&W
Amana SRDE327S3E Ref - SXS/I&W
Amana SRDE327S3L Ref - SXS/I&W
Amana SRDE327S3W Ref - SXS/I&W
Amana SRDE520SBW Ref - SXS/I&W
Amana SRDE520SW Ref - SXS/I&W
Amana SRDE520TBW Ref - SXS/I&W
Amana SRDE520TW Ref - SXS/I&W
Amana SRDE522VE Ref - SXS/I&W
Amana SRDE522VW Ref - SXS/I&W
Amana SRDE528SBW Ref - SXS/I&W
Amana SRDE528SW Ref - SXS/I&W
Amana SRDE528TBW Ref - SXS/I&W
Amana SRDE528TW Ref - SXS/I&W
Amana SRDE528VW Ref - SXS/I&W
Maytag SRH1230ZG Mwave - Mounted Over Range/wo
Maytag SRH1230ZS Mwave - Mounted Over Range/wo
Amana SRI-22E Ref - SXS/I&W
Amana SRI-22E-A Ref - SXS/I&W
Amana SRI-22E-C Ref - SXS/I&W
Amana SRI-22E-G Ref - SXS/I&W
Amana SRI-22E-L Ref - SXS/I&W
Amana SRI19A Ref - SXS/I&W
Amana SRI19A-A Ref - SXS/I&W
Amana SRI19A-AG Ref - SXS/I&W
Amana SRI19A-C Ref - SXS/I&W
Amana SRI19B Ref - SXS/I&W
Amana SRI19B-A Ref - SXS/I&W
Amana SRI19B-C Ref - SXS/I&W
Amana SRI19B-G Ref - SXS/I&W
Amana SRI19B-L Ref - SXS/I&W
Amana SRI19C Ref - SXS/I&W
Amana SRI19C-A Ref - SXS/I&W
Amana SRI19C-C Ref - SXS/I&W
Amana SRI19C-G Ref - SXS/I&W
Amana SRI19C-L Ref - SXS/I&W
Amana SRI19D Ref - SXS/I&W
Amana SRI19E Ref - SXS/I&W
Amana SRI19E-1-A Ref - SXS/I&W
Amana SRI19E-1-C Ref - SXS/I&W
Amana SRI19E-1-G Ref - SXS/I&W
Amana SRI19E-A Ref - SXS/I&W
Amana SRI19E-C Ref - SXS/I&W
Amana SRI19E-G Ref - SXS/I&W
Amana SRI19E-L Ref - SXS/I&W
Amana SRI19E1 Ref - SXS/I&W
Amana SRI19E1L Ref - SXS/I&W
Amana SRI19F Ref - SXS/I&W
Amana SRI19F-1 Ref - SXS/I&W
Amana SRI19F-1-G Ref - SXS/I&W
Amana SRI19F-1-L Ref - SXS/I&W
Amana SRI19F-G Ref - SXS/I&W
Amana SRI19F-L Ref - SXS/I&W
Amana SRI19FA Ref - SXS/I&W
Amana SRI19FC Ref - SXS/I&W
Amana SRI19FG Ref - SXS/I&W
Amana SRI19FL Ref - SXS/I&W
Amana SRI19G Ref - SXS/I&W
Amana SRI19GG Ref - SXS/I&W
Amana SRI19GL Ref - SXS/I&W
Amana SRI19N-1 Ref - SXS/I&W
Amana SRI19N-1-A Ref - SXS/I&W
Amana SRI19N-1-AG Ref - SXS/I&W
  #2 (permalink)
Old 11-20-2012, 09:54 PM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Remove the lower back wall of the freezer section to access the evaporator. The defrost thermostat is clipped to one of the coils on the top of the evaporator. The defrost heater is a cal-rod style and runs down the left side and under the evaporator. Check both for continuity. Check the defrost thermostat while it's frosty. It needs to be below 50*F to show continuity. If both check good, replace the main power board located behind the refrigerator in the machine compartment.
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 11-21-2012, 03:38 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
For Amana, you need to press the fridg door switch five times within 6 seconds.Usually the compressor will stop and the defrost heater will turn on.
If not, you most probably have a bad adaptive defrost circuit in the control board.
__________________
  #4 (permalink)
Old 11-21-2012, 05:55 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
HParts for Amana SRDE27S3E - AppliancePartsPros.comere are your parts
I could not find a tech sheet on this unit with info on how to force a defrost cycle. So have to agree with rickgburton on this one.
Check the defrost heater and the defrost thermostat with a meter.
If both are good then replace the control board (item 9 in the Machine Compartment section)
Only other possibility would be a bad connection/wire and that is very rare.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #5 (permalink)
Old 11-21-2012, 07:13 AM
Junior Member
Default circuit board question
Thanks guys for all the good info, I think I am starting to understand a little more, One question, when you refer to main power board, ADC control board and control board item #9, are these same boards in the same location? I think I know the location of #9 in the lower left corner, front of condensor coil. I did not see any board in back of unit. Could it be in the refrige section
upper left corner?
  #6 (permalink)
Old 11-21-2012, 07:44 AM
Expert
APP Volunteer
Default
All the same board:
Whirlpool 12106802 Board, P.c. - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
