Discuss
defrost timer
 in
Refrigerator & Freezer Repair
I ordered a defrost timer and cannot find where to put the part. Please help.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » defrost timer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-01-2008, 04:54 AM
gretchen gretchen is offline
Junior Member
gretchen is on a distinguished road
Default defrost timer
Model Number: MZD2766GEQ   Brand: Maytag   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-01-2008, 05:00 AM
Junior Member
Default
I ordered a defrost control and cannot find where to put it on my side by side maytag part number er61005988 ADP defrost. Do you have a suggestion.
  #3 (permalink)
Old 02-01-2008, 01:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The adaptive defrost control (#13 on the controls break down diagram) is located in the far right corner inside the housing.
Unplug the refrigerator.
To access the part you have to remove the light shield (#21 on the controls break down diagram) by releasing the tab on each side on the back of the light shield and pulling the part toward yourself.
Then you have to remove the screw on each side of the control panel (#23 on the controls break down diagram) and remove the control panel.
Then you have to remove the screw on each side of the heat shield (#19 on the controls break down diagram) and the screw (#2 on the controls break down diagram) holding the housing to the back wall and carefully pull the housing toward yourself.
Unplug the old PCB and remove it. Install the new one (do not remove the new PCB from the plastic box. It should be installed in the box.
- The part number for the adaptive defrost control is AP3160614
Here are the break down diagrams for the Maytag refrigerator Model MZD2766GEQ
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
where is my defrost timer at hotbrick Refrigerator & Freezer Repair 14 02-06-2008 10:00 PM
Defrost Timer Eric Nathan Refrigerator & Freezer Repair 1 02-01-2008 12:49 PM
Defrost Timer AGAIN Karen S Refrigerator & Freezer Repair 5 01-05-2008 06:12 AM
Defrost timer Greta Elliott Refrigerator & Freezer Repair 2 11-04-2007 12:58 AM
new defrost timer,new heater don419 Refrigerator & Freezer Repair 5 10-12-2007 07:51 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
