We had the power go out during Sandy for approx one day. Since then our ice maker isn't producing any ice. I checked the led codes they seem to be working correctly. Last night i tried to shoot some hot water up the black plastic water tube---not sure how well that actually worked. I also tried the hair dryer. There is no mid tube john guest connector or the back of the fridge ---as i was thinking i could blow some air though it.
Ice maker "fingers" are pointing at approx 10am.
Questions: - how long do i need to use the hair dryer? I may not have done it long enough. - Could it be the ice maker itself? - Other ideas?
Right now i'm thinking the logical issue is a frozen water line created because when the power went out (we have a well) we would have lost water pressure creating the freeze. It's just reading the threads on here about the ice maker no one states how long the hair dryer trick takes.
Thanks for the help!
