Discuss
Refrigerator stops running, still pulling amps
 in
Refrigerator & Freezer Repair
Summary: I have a Whirpool SxS, ED25RFXFW01. Unit has been in the garage for a year, worked until recently. Now
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator stops running, still pulling amps
  #1 (permalink)
Old 11-16-2012, 07:03 PM
Junior Member
texasadam is on a distinguished road
Question Refrigerator stops running, still pulling amps
Model Number: ED25RFXFW01   Brand: Whirlpool   Age: More than 10 years
Summary:
I have a Whirpool SxS, ED25RFXFW01. Unit has been in the garage for a year, worked until recently. Now the unit sometimes runs but will occassionally trip the 20 amp GFCI receptacle it is on. If I unplug and reset GFCI, it will trip when I plug the fridge back in. The GFCI trips when the refrigerator attempts to "run". When I unplug, set temperature to "Off", reset GFCI and plug back in, fridge will pull minimal (0.03) amps and light still works (0.4 amps when on). GFCI will trip when temperature dial is turned back to on.
I moved the fridge to try another non-GFCI plug. When temperature is moved to on, fridge pulls 5-6 amps but isn't cooling and makes no sound (no compressor, no fan). Normally it only pulls around 3 amps when working(amps measured using Kill-A-Watt). Any help or guidance is greatly appreciated.
Full story:
After running perfectly in the garage for a year, of course, one of our kids left the freezer door open and left everything to melt. We dried out the fridge and left it to get cold again. It ran for 1-2 days then tripped the GFCI (and melted...again). We cleaned it, again, and noticed it would trip the GFCI every time we plugged it in or tried to turn it on. I replaced the GFCI device (assuming the previous one was old and maybe worn) with a 20 amp GFCI. Fridge started to run, but would pull high amps (14-15) when starting then resume to 3 amps. I thought it was odd, so I let it sit for a month hoping it just needed time to finish drying or something. Plugged it back in earlier this week and everything was working great, cooled to temp and worked for 36 hours. Then dreaded GFCI tripped this evening. Same behavior as before, GFCI trips when refrigerator tries to run. Moved to another circuit and it pulls 5-6 amps but doesn't run.
I'm not sure if this is something that can be fixed or worth fixing. I'm not sure where to really start troubleshooting. Any help or guidance, or just pointing me in the right direction, is really appreciated!
-Adam
Updates:
** 5 minutes after posting **
I left it unplugged after the fridge tried to pull 6 amps and wouldn't run. 30 minutes later I went to get the model number from inside and plugged it in to get the light to turn on. This time it didn't try to run when it was plugged in, just pulled minimal amps and light worked. Tried multiple times to switch temp on/off, no change - wouldn't run, no load. Left it plugged in while I came inside to type my post and when I went outside again, it was running, cooling, and pulling 2.83 amps. Ugh! I sure wish I knew what was wrong with this thing!
** Update 3 hours later **
The fridge has cooled to 33°F degrees, freezer at about -2°F. Similar pattern as before, seems to work fine and runs for a day or two before acting up again. Maybe short somewhere in the defrost system? Maybe short somewhere in the start system or faulty capacitor?
Ads By Google
Related Models
Whirlpool ED25RFXFW01 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25RFXFW02 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25RFXFW03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25RQXFN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25RQXFN01 REFRIGERATOR
Whirlpool ED25RQXFN02 REFRIGERATOR
Whirlpool ED25RQXFW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25RQXFW01 REFRIGERATOR
Whirlpool ED25RQXFW02 REFRIGERATOR
Whirlpool ED25RQXWW00 Refrigerators*
Whirlpool ED25RQXWW02 Refrigerators*
Whirlpool ED25RQXXW00 REFRIGERATOR
Whirlpool ED25RQXYW00 REFRIGERATOR
Whirlpool ED25RQXYW01 REFRIGERATOR
Whirlpool ED25RQXYW02 REFRIGERATOR
Whirlpool ED25SM1LWR0 Refrigerators*
Whirlpool ED25SM1LWR1 Refrigerators*
Whirlpool ED25SMXLWR0 Refrigerators*
Whirlpool ED25SMXLWR1 Refrigerators*
Whirlpool ED25SMXLWR2 Refrigerators*
Whirlpool ED25SMXRWR0 Refrigerators*
Whirlpool ED25SMXRWR2 Refrigerators*
Whirlpool ED25TEXHN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TEXHN01 REFRIGERATOR
Whirlpool ED25TEXHN02 REFRIGERATOR
Whirlpool ED25TEXHN03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TEXHT02 REFRIGERATOR
Whirlpool ED25TEXHT03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TEXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TEXHW01 REFRIGERATOR
Whirlpool ED25TEXHW02 REFRIGERATOR
Whirlpool ED25TEXHW03 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TQXEN00 REFRIGERATORS
Whirlpool ED25TQXEN01 REFRIGERATOR
Whirlpool ED25TQXEW00 REFRIGERATORS
Whirlpool ED25TQXEW01 REFRIGERATOR
Whirlpool ED25TQXFN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TQXFN01 REFRIGERATOR
Whirlpool ED25TQXFN02 REFRIGERATOR
Whirlpool ED25TQXFN03 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25TQXFW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25TQXFW01 REFRIGERATOR
Whirlpool ED25TQXFW02 REFRIGERATOR
Whirlpool ED25TQXFW03 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25TQXGN00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25TQXGW00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25TWXDN00 REFRIGERATOR
Whirlpool ED25TWXDN01 REFRIGERATOR
Whirlpool ED25TWXDW00 REFRIGERATOR
Whirlpool ED25TWXDW01 REFRIGERATOR
Whirlpool ED25UEXHT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25UEXHT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25UEXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25UEXHW01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25UQXGN00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25UQXGN01 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25UQXGW00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25UQXGW01 SIDE BY SIDE REFRIGERATOR
Whirlpool ED25VFXHT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25VFXHT01 REFRIGERATOR
Whirlpool ED25VFXHT02 REFRIGERATOR
Whirlpool ED25VFXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool ED25VFXHW01 REFRIGERATOR
Whirlpool ED25VFXHW02 REFRIGERATOR
Whirlpool ED25YQXAW00 Refrigerators*
Whirlpool ED26MK1LWR0 Refrigerators*
Whirlpool ED26MK1LWR1 Refrigerators*
Whirlpool ED26MKXLWR0 Refrigerators*
Whirlpool ED26MKXRWR0 Refrigerators*
Whirlpool ED26MM1LWR0 Refrigerators*
Whirlpool ED26MM1LWR1 Refrigerators*
Whirlpool ED26MMXLWR0 Refrigerators*
Whirlpool ED26MMXRWR0 Refrigerators*
Whirlpool ED26MMXRWR2 Refrigerators*
Whirlpool ED26MMXRWR3 Refrigerators*
Whirlpool ED26MMXRWR4 Refrigerators*
Whirlpool ED26SSXLWR0 Refrigerators*
Whirlpool ED26SSXLWR1 Refrigerators*
Whirlpool ED26SSXMWR1 Refrigerators*
Whirlpool ED26SSXRWR0 Refrigerators*
Whirlpool ED27DQXAB03 REFRIGERATOR
Whirlpool ED27DQXAB04 REFRIGERATOR
Whirlpool ED27DQXAB05 REFRIGERATOR
Whirlpool ED27DQXAN02 REFRIGERATOR
Whirlpool ED27DQXAN03 REFRIGERATOR
Whirlpool ED27DQXAN04 REFRIGERATOR
Whirlpool ED27DQXAN05 REFRIGERATOR
Whirlpool ED27DQXAW02 REFRIGERATOR
Whirlpool ED27DQXAW03 REFRIGERATOR
Whirlpool ED27DQXAW04 REFRIGERATOR
Whirlpool ED27DQXAW05 REFRIGERATOR
Whirlpool ED27DQXBB00
Whirlpool ED27DQXBB01 REFRIGERATOR
Whirlpool ED27DQXBB02 REFRIGERATOR
Whirlpool ED27DQXBN00
Whirlpool ED27DQXBN01 REFRIGERATOR
Whirlpool ED27DQXBN02 REFRIGERATOR
Whirlpool ED27DQXBW00
Whirlpool ED27DQXBW01 REFRIGERATOR
Whirlpool ED27DQXBW02 REFRIGERATOR
Whirlpool ED27DQXDB00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED27DQXDB02 REFRIDGERATOR
Whirlpool ED27DQXDB03 REFRIGERATOR
Whirlpool ED27DQXDB04 REFRIGERATOR
Whirlpool ED27DQXDN00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED27DQXDN01 REFRIGERATOR
Whirlpool ED27DQXDN02 REFRIDGERATOR
Whirlpool ED27DQXDN03 REFRIGERATOR
Whirlpool ED27DQXDN04 REFRIGERATOR
Whirlpool ED27DQXDW00 SIDE BY SIDE REFRIGERATOR
Whirlpool ED27DQXDW01 REFRIGERATOR
Whirlpool ED27DQXDW02 REFRIDGERATOR
Whirlpool ED27DQXDW03 REFRIGERATOR
Whirlpool ED27DQXDW04 REFRIGERATOR
Whirlpool ED27DQXWN00 SXS REFRIGERATOR
Whirlpool ED27DQXWN01 SXS REFRIGERATOR
Whirlpool ED27DQXWN10 SXS REFRIGERATOR
Whirlpool ED27DQXWN12 SXS REFRIGERATOR
Whirlpool ED27DQXWW00 Refrigerators*
Whirlpool ED27DQXWW01 Refrigerators*
  #2 (permalink)
Old 11-17-2012, 01:40 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Parts for Whirlpool ED25RFXFW01 Refrigerator - AppliancePartsPros.com
See the attachment for the tech sheet
fridge pulls 5-6 amps but isn't cooling and makes no sound (no compressor, no fan). Normally it only pulls around 3 amps when working.
Sounds to me like you were in a defrost cycle.
No fans or compressor is one clue but so is the amp draw.
Tech sheet says the defrost heater is 21 to 27 ohms.
21 ohms draws 5.7 amp, 27 draws 4.8 amp approx. so you are in that range.
I doubt it is either of the above.
The GFI is probably not tripping because of high current draw.
It is probably just seeing a small unaccounted for current (milli-amps).
My guess is that it will run without problems on a non-GFI outlet.
The GFI monitors the amps on the live side and the amps on Neutral, if they are different by a few milli-amps, it trips because that current must be going somewhere. That somewhere may be through your body or so it assumes.
If you have to run it on a GFI outlet, finding the fault will probably be a pain.
All it takes is a little moisture path between a live wire/connection for the GFI to trip.
First unplug he unit and remove the cover in the freezer.
Check the defrost thermostat. If it is deformed/bulged replace it. It has water in it and this is allowing current to flow to ground.
Check that the heater, defrost and wiring connectors are dry.
The parts breakdown does not show how the defrost thermostat is installed. If it uses wire nuts, redo the connections. Point the wire nuts down so water cannot get into them. Some folks like to seal the open ends with some sealant as an extra precaution.
Check that the heater is in good shape. No cracks in it's wires etc.
I always try to use non-GFI receptacles on fridges.
This is still safe.
In order for you to get a shock several things have to happen.
1. A live wire must short to the units frame.
2. You must also loose the ground and Neutral connection.
3. You must be grounded.
If a short happens with Neutral still attached the unit will trip the breaker/fuse in the electrical panel.
If Neutral is also lost then the voltage is directed to the ground connection and again the breaker will trip.
Note: All the above is just speculation on my part and it may well be a problem with the compressor or start device but this is where I would start.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE refrigerator (TFX22CRBWW) stops running on its own RamJacCorp Refrigerator & Freezer Repair 0 08-11-2012 09:32 AM
Is 2.5 amps too high for refrigerator compressor? bradleyg Refrigerator & Freezer Repair 6 11-01-2011 07:36 AM
GE refrigerator cold air in freezer stops running CathyRN Refrigerator & Freezer Repair 0 04-24-2011 07:46 PM
Refrigerator stops running every few days Jim_istok Refrigerator & Freezer Repair 1 03-01-2011 01:26 PM
refrigerator stops running tbollm1 Refrigerator & Freezer Repair 4 12-27-2009 02:55 PM
