| » Groaning Fridge - Replaced Board, Still Noisy |
Model Number: PSS26SGPASS Brand: GE Age: 5 - 10 years
My GE Profile refrigerator is cooling fine, but the freezer fan has been groaning for some time. The pitch goes up and down frequently and is driving the family crazy. After reading several posts on this forum, I replaced the main control board. I didn't have any burned resistors. I still hear the noise.
Would you suggest replacing the evaporator fan motor? I have also heard reports that this noise may be caused by ice/frost on the fan blades. Ever heard of this? Thank you for your help. Ads By Google Related Models |
Is there anything else that is changing, like the compressor turning off? If not, remove the freezer back panel and try to isolate the noise, might be just the panel vibrating, or the evaporator tubing.
__________________
I'm not sure if the factory tape was attached. I'm out of town today, but will check when I get home. The bubble wrap inside the box sure didn't seem original. It was two different types/sizes of bubbles. I bought the part from appliancepartspros.com
Turns out the original packaging tape had been cut with additional tape put over it, so I likely had a used board. I also ordered a new evaporator fan, but after opening the rear panel of the freezer determined that I needed a fan with thermistor, even through my model number (PSS26SGPASS) doesn't call for one according to the appliancepartspro website. I guess I'll be returning both of these parts and start over.
I would not return the evaporator fan motor, a lot of the GE refrigerators specify the motor that was sent. You will just have to splice in the new fan motor with in line splices, sorry, you can blame GE for that, not this site.
__________________
| Display Modes | |
| Replaced control board | kmitchus | Oven Repair (including Ranges and Cooktops) | 0 | 11-28-2011 07:15 PM |
| Replaced broken belt now it's noisy! | DrkSdeOTM | Dryer Repair | 0 | 08-30-2011 09:25 PM |
| Replaced mother board... now what | Jeff1234 | Refrigerator & Freezer Repair | 1 | 05-26-2011 04:08 PM |
| Ge refrigerator. Repairman replaced mother board today now freezer is 24 and fridge 4 | Ejg05vet | Refrigerator & Freezer Repair | 5 | 04-17-2011 03:41 PM |
| High voltage surge damaged the control board,replaced board,compressor still not runn | shillion | Refrigerator & Freezer Repair | 0 | 11-16-2010 01:18 AM |
