EGSchmid
#1 Posted : Friday, November 9, 2012 9:14:55 AM(UTC)
EGSchmid
Dispenser Front parts for Whirlpool KSRY25CVMS01 - AppliancePartsPros.com
I have this refrigerator and the part that i need on this drawing is #1 but it does not give me the option of buying it.
The cubes were falling out and water was dripping so I then noticed the door would not shut. After taking apart I found out the part 1 on the drawing is broken that holds part 7 and 11
How can I buy part 1 from this drawing? When i tried to remove it appears that maybe it is glued/taped to the door and quite difficult. I am concerned that i cannot even remove it at all to fix the ice dispenser. My attempt to remove caused it to bend so I stopped to avoid further damage.
Right now my ice dispenser is taped shut and not usable. I taped it to avoid the warm air from melting the ice. We are now just opening the door and removing the ice manually.
rickgburton
#2 Posted : Friday, November 9, 2012 12:36:08 PM(UTC)
rickgburton
Groups: Expert
That part is a non-serviceable item and I've never needed one. You might just need Part# 8201649
EGSchmid
#3 Posted : Friday, November 9, 2012 1:23:37 PM(UTC)
EGSchmid
Thanks but those parts are not broken. The part 1 from the diagram that these connect to. I have since determined that it requires buying the entire freezer door as this is an all in one part and cannot be solid separately. $550+
rickgburton
#4 Posted : Friday, November 9, 2012 1:46:52 PM(UTC)
rickgburton
Groups: Expert
Ka-Ching!! Get some epoxy and super glue and be creative.
Broken ice dispenser door (Refrigerator & Freezer Repair)
by fbomb 2/1/2010 4:24:08 PM(UTC)
broken ice dispenser (Refrigerator & Freezer Repair)
by Duke33 11/28/2008 10:21:40 AM(UTC)
Broken Ice Dispenser Housing Tab (Refrigerator & Freezer Repair)
by whirlfrost 10/11/2008 10:01:39 AM(UTC)
