Discuss
Freezer not cold enough, compressor keep running
 in
Refrigerator & Freezer Repair
Hey, I have a Maytag side-by-side freezer/fridge, white,no icemaker, maybe 15yrs or older. Sorry, really can't seem to find the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer not cold enough, compressor keep running
  #1 (permalink)
Old 11-07-2012, 09:48 AM
Junior Member
hohaapp is on a distinguished road
Default Freezer not cold enough, compressor keep running
Brand: Maytag   Age: More than 10 years
Hey, I have a Maytag side-by-side freezer/fridge, white,no icemaker, maybe 15yrs or older. Sorry, really can't seem to find the model number.
The freezer side does get cold, but not cold enough. Inside of the freezer, the lower half of the back wall is full of frost. Refridgeration side is working fine.
The compressor does not stop working. Maybe it runs day and nights non-stop.
Where should i start to trouble shoot?
--------------------------Update----------------
Followed Denman's instruction:
1. while fridge on, turn the timer. Heater does not go hot, not even warm.
Question: How long does it take the heaters to get hot to the touch?
2. checked continuity of thermostat and heater, both returned 0 ohm.
3. took out timer, turned the timer , tested legd 1 -2, got 0ohm ; and turned timer, tested 1-4.returned 0ohm. Put the timer back on the fridge, turned it to defrost cycle, waited 40mins, compressor never turned on.
So, I went to get a new timer. Put it on fridge. Just got it on, during the defrost cycle, the heater is still not warm...
Could it be something else?
Thanks a lot
Ads By Google
  #2 (permalink)
Old 11-07-2012, 10:53 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Perhaps the following will help you find the model number.
Remove the rear cover in the freezer so you can inspect the evaporator coil.
If heavily frosted/iced over to the point where the evaporator fan cannot pull air through it, you have a defrost problem.
If it is just frosted in one area, usually where the freon enters the coil, it is probably a sealed system problem. This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit.
Make sure the evaporator fan runs.
__________________
  #3 (permalink)
Old 11-07-2012, 03:23 PM
Junior Member
Default
Thanks for the reply.
If I find out it is the defrost problem, what do I do?
Change the fan?
  #4 (permalink)
Old 11-08-2012, 02:16 AM
Senior Expert
APP Volunteer
Default
Just add a post with the model number.
Some units use a timer but others use electronic control of the defrost.
__________________
  #5 (permalink)
Old 11-08-2012, 08:24 AM
Junior Member
Default
here r some pics . can't see model no.
there used to be a black tar paper on lower back panel. long gone.
  #6 (permalink)
Old 11-08-2012, 09:50 AM
Junior Member
Default
here are the pics of the back of the fridge .No model no.
Inside of the fridge, I checked too. no luck.
  #7 (permalink)
Old 11-08-2012, 09:54 AM
Junior Member
Default
Opened the freezer inside panel. The evaporator is full of frost. Can't see the fan. Please see pics.
  #8 (permalink)
Old 11-08-2012, 12:42 PM
Senior Expert
APP Volunteer
Default
You have a defrost problem.
Now we have to figure out the cause.
The defrost system is made up of a defrost heater, a defrost thermostat and the defrost timer or adaptive defrost board.
Also some units control defrost from the main control board but this is usually on later model years.
Now all we have to do is find what it uses.
An adaptive defrost board is usually in the control console in the fresh food section.
A defrost timer can be at the back of the unit but I do not see one in your picture.
Could be behind the kick plate, often you cannot see the actual timer due to the mounting bracket blocking your view.
Could be in the control console in the fresh food section.
Usually there will be a hole so you can see/turn the timer cam without taking anything apart.
Following is an example of what the timer will look like, click on the picture for more views.
Part number: AP2111929
Once we find what controls the defrost you may be able to get a part number off it and then we can work backwards to find out what is causing the defrost problem.
__________________
  #9 (permalink)
Old 11-08-2012, 03:11 PM
Junior Member
Cool
.3.
I will look for the hole for the timer...
Would I be able to see any thing to find the Adaptive Defrost Board?
  #10 (permalink)
Old 11-08-2012, 03:30 PM
Junior Member
Default
Should I also do the continuity check on the thermostat and the heater?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid compressor running, no cold bagadonitz Refrigerator & Freezer Repair 2 07-31-2012 11:00 AM
freeze cold but compressor never stop running Nomad Terry Refrigerator & Freezer Repair 5 11-10-2011 01:35 AM
Ffrige and freezer cold - compressor still running broman Refrigerator & Freezer Repair 0 08-25-2011 08:21 PM
Freezer running extra cold and frig running warm elora97 Refrigerator & Freezer Repair 2 05-23-2010 04:51 PM
freezer running non stop, fridge is not running but staying cold galvatron Refrigerator & Freezer Repair 1 10-05-2009 04:17 PM
