Discuss
water and Ice dispenser
 in
Refrigerator & Freezer Repair
ON the water and Ice dispenser we get water but we cant get ice or crushed ice in cup what
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water and Ice dispenser
  #1 (permalink)
Old 11-06-2012, 04:28 PM
Junior Member
johnmusumeci is on a distinguished road
Default water and Ice dispenser
Model Number: RST2400FAE   Brand: Maytag   Age: Less than 1 year
ON the water and Ice dispenser we get water but we cant get ice or crushed ice in cup what could be causing this
pulled ice bin out the part that make auger work makes the auger turn the yoke is turning very slowly then when the bin is placed back into freezer it stops completly and you can hear something running but auger does not turn
Ads By Google
Related Models
Maytag RST2400FAE Ref - SXS/I&W
Maytag RST2400FAM Ref - SXS/I&W
Amana RST307 Range - S/c S/i Ddraft Gas
Amana RST307/ALL Range - S/c S/i Ddraft Gas
Amana RST3079310 Range - S/c S/i Ddraft Gas
Amana RST307F043 Range - S/c S/i Ddraft Gas
Amana RST307UWW Range - S/c S/i Ddraft Gas
Amana RST308U Range - S/c S/i Ddraft Gas
Amana RST308UK Range - S/c S/i Ddraft Gas
Amana RST308UL Range - S/c S/i Ddraft Gas
Amana RST308UW Range - S/c S/i Ddraft Gas
Amana RST308UWW Range - S/c S/i Ddraft Gas
Amana RST309 Range - S/c S/i Ddraft Gas
Amana RST309/ALL Range - S/c S/i Ddraft Gas
Amana RST310UK Range - S/c S/i Ddraft Gas
Maytag RST310UK  Range - S/c S/i Gas
Amana RST310UL Range - S/c S/i Ddraft Gas
Maytag RST310UL  Range - S/c S/i Gas
Amana RST310UW Range - S/c S/i Ddraft Gas
Maytag RST310UW  Range - S/c S/i Gas
Amana RST310UWW Range - S/c S/i Ddraft Gas
Maytag RST310UWW  Range - S/c S/i Gas
Amana RST354 Range - S/c S/i Ddraft Gas
Amana RST354/ALL Range - S/c S/i Ddraft Gas
Amana RST359 Range - S/c S/i Ddraft Gas
Amana RST359/ALL Range - S/c S/i Ddraft Gas
Amana RST361 Range - S/c S/i Ddraft Gas
Amana RST361/ALL Range - S/c S/i Ddraft Gas
Amana RST362 Range - S/c S/i Ddraft Gas
Amana RST362/ALL Range - S/c S/i Ddraft Gas
Amana RST365/ALL Range - S/c S/i Ddraft Gas
Amana RST369 Range - S/c S/i Ddraft Gas
Amana RST369/ALL Range - S/c S/i Ddraft Gas
Amana RST376 Range - S/c S/i Ddraft Gas
Amana RST376/ALL Range - S/c S/i Ddraft Gas
Amana RST378/ALL Range - S/c S/i Ddraft Gas
Amana RST378UL Range - S/c F/s Gas
Maytag RST378UL  Range - S/c F/s Gas
Amana RST378UW Range - S/c S/i Ddraft Gas
Amana RST378UWG Range - S/c S/i Ddraft Gas
Amana RST380 Range - S/c S/i Ddraft Gas
Amana RST380/ALL Range - S/c S/i Ddraft Gas
Amana RST381 Range - S/c S/i Ddraft Gas
Amana RST381/ALL Range - S/c S/i Ddraft Gas
Amana RST382U Range - S/c S/i Ddraft Gas
Amana RST382UK Range - S/c S/i Ddraft Gas
Amana RST387 Range - S/c S/i Ddraft Gas
Amana RST387/ALL Range - S/c S/i Ddraft Gas
Amana RST387UWW Range - S/c S/i Ddraft Gas
Amana RST388U Range - S/c S/i Ddraft Gas
Amana RST388UWW Range - S/c S/i Ddraft Gas
Amana RST399UL Range - S/c S/i Ddraft Gas
Amana RST399UW Range - S/c S/i Ddraft Gas
Maytag RSW2200AAE Ref - SXS/I&W
Maytag RSW2200AAL Ref - SXS/I&W
Maytag RSW2200AAW Ref - SXS/I&W
Maytag RSW2200BAE Ref - SXS/I&W
Maytag RSW2200CAE Ref - SXS/I&W
Maytag RSW2200CAL Ref - SXS/I&W
Maytag RSW2200CAW Ref - SXS/I&W
Maytag RSW2200EAE Ref - SXS/I&W
Maytag RSW2200EAM Ref - SXS/I&W
International RSW2250AGE Ref - SXS/I&W
Maytag RSW22A Ref - SXS/I&W
Maytag RSW22E0CAE Ref - SXS/I&W
  #2 (permalink)
Old 11-07-2012, 03:51 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
See if you're getting 120 VAC to the auger motor when the lever is pressed. If so replace the auger motor. If not check the microswitch in the dispenser for continuity.
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 11-07-2012, 08:23 AM
Banned
jacklance is on a distinguished road
Default
The cubed feature is activated by a solenoid that raises an arm on the side of the ice storage bucket. This raises a flapper that allows the ice to bypass the cutting grid that makes crushed ice. Either the wire activating arm is not inserted into the solenoid cradle properly, or the solenoid is bad. When you select "cubes" & activate the dispenser, you should hear a loud "snap" as the solenoid operates.
  #4 (permalink)
Old 11-07-2012, 02:53 PM
Expert
APP Volunteer
Default
Hi Jack, he said he wasn't getting cubed or crushed out of the dispenser. The solenoid position wouldn't make any difference. It sounds like maybe an auger issue. What do you think?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water dispenser--low pressure. Ice maker--hollow ice cubes and dispenser problem uswdyp47 Refrigerator & Freezer Repair 0 09-05-2012 11:14 PM
Water Dispenser Works, Ice Dispenser (Crushed or Cubed) Is falchion1966 Refrigerator & Freezer Repair 0 10-18-2011 04:48 PM
Water Dispenser no flow, leak and ice buildup in ice dispenser scott-optrex Refrigerator & Freezer Repair 3 05-31-2011 07:08 AM
Intermittent Water dispenser, Ice dispenser failure HRS flashing in display window Niko33 Refrigerator & Freezer Repair 2 02-28-2011 07:29 AM
water dispenser, light in dispenser area and ice dispense not working dkusko Refrigerator & Freezer Repair 0 11-26-2010 10:31 AM
