| » Ge side by side door between freezer won't open |
Model Number: Gsl25jfpa bs Brand: GE Age: 5 - 10 years
Freezer seems fine but small door between freezer and fridge won't open. temp sensor below small door in fridge manually made warm won't trigger actuator. Mother board?????? Need help. Thank you
Push the damper half way closed and unplug the refrigerator to reset the motherboard. Set the temperature controls at 5 and 5 and restore power. The damper door should move immediately after restoring power. You have ten seconds to check it. If the damper door moves, verify the thermistor(s) is within range. (16.3K ohms at 32*F). If the thermistor(s) resistance is within range,replace the motherboard. If the damper door does not move when power is restored, disconnect the harness connector at the damper and use an ohmmeter to measure the resistance between the yellow and red/black wires and between the white/brown and blue/yellow wires. Your meter should show 420 ohms for both readings. If not, replace the damper. If the ohms are correct, disconnect the J3 connector on the motherboard and unplug the machine. Restore power to the machine. Check for 6 VDC between J4 Pin3 (Common) and each of the pins J3-1,J3-2, J3-3 and J3-4. If the VDC in not correct, replace the motherboard.
__________________
Ricks Appliance Repair Last edited by rickgburton : 11-07-2012 at 03:42 AM. |
| Display Modes | |
| how do I replace water line in freezer door of whirlpool side by side | Todd Overton | Refrigerator & Freezer Repair | 33 | 02-18-2013 05:19 PM |
| No Airflow In Frigerator Side Unless Freezer Door Open | serviceDee | Refrigerator & Freezer Repair | 0 | 07-08-2012 08:24 AM |
| Removing Freezer door/water line on side-by-side to install new cam riser | RSMBob | Refrigerator & Freezer Repair | 3 | 03-05-2012 01:37 PM |
| Side by Side model freezer door keeping water line frozen | fisshen99 | Refrigerator & Freezer Repair | 0 | 11-14-2010 02:12 PM |
| Refrigerator door on side by side is diffcult to open | rmizikar | Refrigerator & Freezer Repair | 0 | 12-28-2009 06:28 PM |
