Good Morning. I have replaced the water valve . The first one did not correct the problem and you sent me a replacement however, there is still no water going from the valve to the ice maker. I have replace the water line and I poured water into the ice maker and it works that way. It also goes thru the cycle of the arm raising but still no water in the green turn from the valve to the ice maker. Nothing frozen in the line. I have checked that...PLEASE help! :rolleyes:
