HELP!! Old and single, and I have "NO IDEA". I posted earlier this week/later today regarding this frig, and I needed the model number. It wasn't cooling at all then.
Today . . Both sides are cooling, but the freezer is not cold enough to freeze, and really I'd like my frig a bit colder. Everything is blowing and going, I hear the motor turn on and off. 2 days ago I was pushing, pulling, turning on the controls, to turn and change degree's of cold. It worked, but as above not freezing or cold enough.
Can it be the thermastats out of whack or is it something else. Being a 1991 frig is it worth the fix I need to accomplish for usage. I'm in a quandary:eek:
Thank you, pattip
