| » Whirlpool GSS26C5XXY00 ice maker not filling with water |
Model Number: GSS26C5XXY00 Brand: Whirlpool Age: 1 - 5 years
Ice maker just recently quit filling with water and therefore no more ice. Water dispenser works fine.
Switched wires on Water inlet valve and still no water to ice maker. Thought this indicated a bad solenoid for the ice maker waterline and replaced water inlet valve. No change. There are two door switches in the upper left of the freezer compartment. Lower switch will turn off lights and "door open" indicator on front of dispenser. Upper switch seems to do nothing. Fill tube has a heater on it so I dismissed the possibility of a frozen tube. Tube would be VERY difficult to access. I see there is a photo eye in the ice bin to stop ice maker when bin gets full, but when I put an infrared detector in front of it, it does not glow. I found the "Modular Ice Maker & Ice Level Detector Service Sheet" folded up in the front kick plate and I performed the Optics Diagnostic Procedure. The Status LED is on solid, indicating that the optics are working correctly. Should I try all the Ohmmeter and Voltage checks, or should I move on to something else? Ads By Google Related Models |
| Display Modes | |
| GE Ice Maker not filling w/ water | ffizzino | Refrigerator & Freezer Repair | 2 | 12-23-2012 01:38 PM |
| Ice Maker Not Filling With Water | ouhogfan | Refrigerator & Freezer Repair | 0 | 02-08-2012 12:01 PM |
| ice maker not filling up with water | TIMNALLISON | Refrigerator & Freezer Repair | 0 | 09-04-2011 02:02 PM |
| water not filling ice maker | patnaude8 | Refrigerator & Freezer Repair | 0 | 07-30-2011 10:02 AM |
| Ice Maker not filling with water | AlphaBob | Refrigerator & Freezer Repair | 3 | 05-24-2009 08:25 PM |
