| » Water flow is weak |
Model Number: MFD2561HEW Brand: Maytag Age: 5 - 10 years
Our water tap on left side of the unit has drastically lost its flow. We have changed out filters on a pretty consistent basis over the years, and recently put in a new one once this issue developed. Basically, if not used for a 10 minutes or more, the water will flow normally for a few seconds, and then it will drop to a slow stream.
A new filter didn't really help at all - what parts should I change out? thanks! Ads By Google Related Models |
Replacing the valve didn't work - the same issue. So, I've changed the water filter, and the valve. What is the next thing it could be? thanks!
I have checked all of this. I removed it and filled with hot water in case coil to dispenser had some issues. The same thing happens. Full power for a few seconds, then back to slow, weak flow.
It seems that the problem has to be something to do with the water filter area, everything else has been checked. (I did buy a new filter, that didn't fix it either) |
| Display Modes | |
| Agitation get very weak after 5 min and starts to leak water | jplamarre | Washer Repair | 4 | 08-29-2012 09:05 PM |
| Maytag Top load has weak water pressure on Rinse | Chopper5150 | Washer Repair | 7 | 03-16-2012 01:32 PM |
| weak water flow from kenmore refrigerator | bnorman | Refrigerator & Freezer Repair | 0 | 08-16-2011 10:54 AM |
| Weak gas flow | Mike362 | Oven Repair (including Ranges and Cooktops) | 1 | 11-30-2009 01:00 PM |
| water entering in weak stream | Kimby | Washer Repair | 1 | 03-07-2008 05:13 PM |
