Discuss
Maytag fridge warm & no ice build up
 in
Refrigerator & Freezer Repair
I have a Maytag MZD2766GES that quit working last night. I have power to unit. It is warm on both
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Maytag fridge warm & no ice build up
  #1 (permalink)
Old 10-31-2012, 09:25 AM
Junior Member
MikeinDerby is on a distinguished road
Default Maytag fridge warm & no ice build up
Model Number: MZD2766GES   Brand: Maytag   Age: 5 - 10 years
I have a Maytag MZD2766GES that quit working last night. I have power to unit. It is warm on both sides. There is no ice build up on the freezer side and the freezer fan is running. Took of back panel to inspect all good. When I turn the temp control down still stays warm. When I turn temp control off the fans shut down. I took the lower compressor cover off. The cooling fan for the coil is running. The compressor appears cool and I believe it is not running. I had a recall completed on April of 2009 for the replacement of the Overload switch assembly. I'm not sure if I need to replace the overload switch again or the capacitor or both?
Ads By Google
Related Models
Maytag MZD2766GES Ref - SXS/I&W
Maytag MZD2766GEW Ref - SXS/I&W
Maytag MZD2768GEB Ref - SXS/I&W
Maytag MZD2768GEQ Ref - SXS/I&W
Maytag MZD2768GEW Ref - SXS/I&W
Norge N1100PAW Range - F/s Std Gas
Norge N1100PRA Range - F/s Std Gas
Norge N1100PRA-L Range - F/s Cont Clean Gas
Norge N1100PRW Range - F/s Std Gas
Norge N1100PRW-L Range - F/s Cont Clean Gas
Norge N1500PRA Range - F/s Std Ele
Norge N1500PRW Range - F/s Std Ele
Norge N31100PAA Range - F/s Std Gas
Norge N31100PAW Range - F/s Std Gas
Norge N3110KRA Range - F/s Std Gas
Norge N3110KRW Range - F/s Std Gas
Norge N3110PPA Range - F/s Std Gas
Norge N3110PPW Range - F/s Std Gas
Norge N3110PRA Range - F/s Std Gas
Norge N3110PRW Range - F/s Std Gas
Norge N31111XAA Range - F/s Std Gas
Norge N31111XAW Range - F/s Std Gas
Norge N31115WAV Range - F/s Std Gas
Norge N31115XAA Range - F/s Std Gas
Norge N31115XAW Range - F/s Std Gas
Norge N3120SPA Range - F/s Std Gas
Norge N3120SPN Range - F/s Std Gas
Norge N3120SPW Range - F/s Std Gas
Norge N3120SRA Range - F/s Std Gas
Norge N3120SRW Range - F/s Std Gas
Norge N3121XPA Range - F/s Std Gas
Norge N3121XPW Range - F/s Std Gas
Norge N3121XRA Range - F/s Std Gas
Norge N3121XRW Range - F/s Std Gas
Norge N3121XTA Range - F/s Std Gas
Norge N3121XTW Range - F/s Std Gas
Norge N3137XRA Range - F/s Std Gas
Norge N3137XRW Range - F/s Std Gas
Norge N3137XUA Range - F/s Std Gas
Norge N3137XUW Range - F/s Std Gas
Whirlpool N3157W0
Whirlpool N3157W1
Whirlpool N3157^0
Whirlpool N3157^1
Norge N3177VUV Range - F/s Std Gas
Norge N3177XRA Range - F/s Std Gas
Norge N3177XRW Range - F/s Std Gas
Norge N3177XUA Range - F/s Std Gas
Norge N3177XUW Range - F/s Std Gas
Whirlpool N3257W0
Whirlpool N3257W1
Whirlpool N3257^0
Whirlpool N3257^1
Whirlpool N3357W0
Whirlpool N3357^0
Norge N3422PRA Range - S/c F/s Gas
Norge N3422PRW Range - S/c F/s Gas
Norge N3438SRA Range - S/c F/s Gas
Norge N3438SRW Range - S/c F/s Gas
Norge N3438VRV Range - S/c F/s Gas
Whirlpool N3457W0
Whirlpool N3457^0
Norge N3472SRA Range - S/c F/s Gas
Norge N3472SRW Range - S/c F/s Gas
Norge N3478VRV Range - S/c F/s Gas
Norge N3478VVV Range - S/c F/s Gas
Norge N3478XRA Range - S/c F/s Gas
Norge N3478XRW Range - S/c F/s Gas
Norge N3478XVA Range - S/c F/s Gas
Norge N3478XVW Range - S/c F/s Gas
Norge N3510KRA Range - F/s Std Ele
Norge N3510KRW Range - F/s Std Ele
Norge N3510PPA Range - F/s Std Ele
Norge N3510PPW Range - F/s Std Ele
Norge N3510PRA Range - F/s Std Ele
Norge N3510PRW Range - F/s Std Ele
Norge N3520SPA Range - F/s Std Ele
Norge N3520SPN Range - F/s Std Ele
Norge N3520SPW Range - F/s Std Ele
Norge N3520SRA Range - F/s Std Ele
Norge N3520SRW Range - F/s Std Ele
Norge N3521XPA Range - F/s Std Ele
Norge N3521XPW Range - F/s Std Ele
Norge N3521XRA Range - F/s Std Ele
Norge N3521XRW Range - F/s Std Ele
Norge N3832XRA Range - S/c F/s Ele
Norge N3832XRW Range - S/c F/s Ele
Norge N3875XRA Range - S/c F/s Ele
Norge N3875XRW Range - S/c F/s Ele
Norge N3878VRV Range - S/c F/s Ele
Norge N3878VVD Range - S/c F/s Ele
Norge N3878VVV Range - S/c F/s Ele
Norge N3878XRA Range - S/c F/s Ele
Norge N3878XRW Range - S/c F/s Ele
Norge N3878XVA Range - S/c F/s Ele
Norge N3878XVW Range - S/c F/s Ele
Magic Chef N40C-3-X9 Mwave - Cntrtp / Stand Alone
Norge N4231WRA Range - F/s Cont Clean Gas
Norge N4231WRW Range - F/s Cont Clean Gas
Norge N4251WTA Range - F/s Std Gas
Norge N4251WTW Range - F/s Std Gas
Whirlpool N9157L0
Whirlpool N9157L1
Whirlpool N9157X0
Whirlpool N9157^0
Whirlpool N9157^1
Whirlpool N9257L1
Whirlpool N9257L2
Whirlpool N9257X0
Whirlpool N9257X1
Whirlpool N9257^0
Whirlpool N9257^1
Whirlpool N9257^2
Whirlpool N9357L0
Whirlpool N9357L2
Whirlpool N9357L3
Whirlpool N9357^0
Whirlpool N9357^2
Whirlpool N9357^3
Whirlpool N9457L3
  #2 (permalink)
Old 10-31-2012, 04:45 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Use the multimeter to check the continuity of the compressor's three pins between them and no continuity to the ground.
If that what you have - replace the relay/overload kit.
For the serial # starting with 27 and less Part number: 12002784
For the serial # 28 and more Part number: 12002794
Here are the breakdown diagrams and 01-Compressor parts for Maytag MZD2766GES - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-02-2012, 02:20 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Monitor the two power wires to the compressor, if no voltage, you have other problems.
__________________
  #4 (permalink)
Old 11-09-2012, 07:28 AM
Junior Member
Default
Replaced Compressor Starter Relay, Fixed it Thanks
  #5 (permalink)
Old 11-09-2012, 11:15 AM
Expert
Default
Hi.
You are very welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No ice, warm fridge, frezzer ok, frost build-up alltrees Refrigerator & Freezer Repair 13 07-09-2012 06:50 PM
fridge and freezer warm no frost build up warsword Refrigerator & Freezer Repair 0 03-28-2011 02:38 PM
Maytag Fridge warm daltonan Refrigerator & Freezer Repair 3 02-15-2011 05:21 AM
Maytag Fridge warm, freezer seems OK jonathanvandyck Refrigerator & Freezer Repair 1 12-24-2009 06:53 AM
Freezer frost build up & fridge getting warm jamez8531 Refrigerator & Freezer Repair 1 10-10-2008 04:19 AM
