Discuss
Installing new compressor
 in
Refrigerator & Freezer Repair
trying to install new compressor but have a few questions, about the capalary tube w/ the charging /service port, this
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Installing new compressor
  #1 (permalink)
Old 10-30-2012, 12:21 PM
Junior Member
jim martin is on a distinguished road
Question Installing new compressor
Brand: Crosley   Age: Less than 1 year
trying to install new compressor but have a few questions, about the capalary tube w/ the charging /service port, this compressor comes w/ a device that looks like a capalary tube/ line dryer ? that has a charging/svvc. port where does that part sweat on to compressor? the compressor has 3 ports one for high and one for low, the other must be a svc port im guessing, any help would be appreaciated.
Ads By Google
  #2 (permalink)
Old 10-31-2012, 06:01 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You need expensive equipent and knowledge to install a compressor. Most of the novices that asked for help on this forum damaged the compressor. I have not replaced one in 10 years due to the high cost of compressors and logistic/ management costs. Best to have it installed by a pro. which is rather expensive.
__________________
  #3 (permalink)
Old 10-31-2012, 07:02 AM
Junior Member
Default
I am a hvac tech. but a friend got his compressor under warranty and it came w/ no paper work on where the charging port goes,
  #4 (permalink)
Old 10-31-2012, 09:02 AM
Senior Expert
APP Volunteer
Default
The charging port is the processing tube, usually 5/16 size.I usually put a BP piercing valve on it. The dryer is installed on the high side, but the gauge fitting is for checking the high side pressure and a needed fitting for sucking down the high side.
Most failures are from non-compressables that damage the compressor where it will not produce "normal" vacumm pressure.
__________________
  #5 (permalink)
Old 12-23-2012, 04:56 AM
Junior Member
slugranch is on a distinguished road
Default
Find the existing dryer & Cap tube, remove and replace them, and evacuate and recharge system,,,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installing Compressor start device kit mdodson Refrigerator & Freezer Repair 1 08-20-2011 09:11 AM
installing thermal overload and components on new compressor Craig Golembiewski Refrigerator & Freezer Repair 0 03-01-2011 09:11 AM
Installing a Starter Device Kit EGY 90 compressor Carol Doorn Refrigerator & Freezer Repair 1 02-13-2011 02:26 AM
Installing New Starting device kit, compressor Mike717 Refrigerator & Freezer Repair 1 04-13-2010 05:48 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
