Discuss
water leaking into refrigerator
 in
Refrigerator & Freezer Repair
Water periodically streams into my refrigerator from above. The freezer is on top. What is wrong? How do I stop
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water leaking into refrigerator
  #1 (permalink)
Old 01-31-2008, 12:57 PM
Rebekah Durham Rebekah Durham is offline
Junior Member
Rebekah Durham is on a distinguished road
Question water leaking into refrigerator
Model Number: 70962990   Brand: Kenmore   Age: 5 - 10 years
Water periodically streams into my refrigerator from above. The freezer is on top. What is wrong? How do I stop it. I've already turned the ice-maker off and it still happens.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-31-2008, 04:44 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default drain plugged
This most likely is happening during a defrost cycle and it's because the evaporator pan drain is plugged with ice, debris, etc... Turn off the fridge and remove food items from the freezer... Locate screws on the inside rear cover of the freezer compartment and remove this cover exposing the evaporator coil and fan assy... Under the coil is the pan which catches condensate during the defrost cycle, this pan will have a drain tube... You may need to use a hair dryer if the pan is filled with ice... Use hot water and a turkey baster to melt ice inside the tube... Once water flows freely to the condensate pan underneath the fridge then it won't drip into your fridge during defrost...
__________________
  #3 (permalink)
Old 08-10-2008, 01:39 PM
southjm11 southjm11 is offline
Junior Member
southjm11 is on a distinguished road
Default water leaking into refrig - drain plugged
This seems like my problem but not sure what frig explanation is for.
Mine is a Whirpool model no. ET1CHMXKQ02
What is correct procedure & parts to clear plug?
Thanks!
Jim
  #4 (permalink)
Old 08-11-2008, 12:51 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jim,
You can use all of the instructions given by Kooler in the above post.
Here are the break down diagrams for the Whirlpool refrigerator Model ET1CHMXKQ02
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gibson Refrigerator leaking Johnson Refrigerator & Freezer Repair 1 09-08-2008 03:59 PM
Ice Maker water leaking pothole914 Refrigerator & Freezer Repair 0 01-13-2008 08:49 AM
Water leaking into the tub shirl723 Washer Repair 4 10-19-2007 07:17 AM
Leaking Refrigerator DeBucket Refrigerator & Freezer Repair 1 09-25-2007 10:58 AM
Water leaking into refrigerator compartment cw.lewis Refrigerator & Freezer Repair 1 07-25-2007 01:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
