Left door, water and ice (crushed or cubed) dispenser. Everything works except cubed option, water, crushed ice, light, but no cubed. Whats my path to repair?
thanks
Groups: APP Team
Hi. You need to check the cube solenoid visually and for continuity. Pull out the ice bin, icemaker and rear cover to get to the solenoid. If the solenoid checks out OK - see if it's getting 120VAC: (with the door switch closed) push the ice lever. The ice cube solenoid Part number: WR62X58
