| » Refrigator to cold |
Model Number: PSW26MSRE-SS Brand: GE Age: 1 - 5 years
Refrigerator at about 32 degrees with setting of 1. Freezer at +5 degrees with setting of 2.
Fridge fan assenbly/diverter checks out OK. Freezer fan runs continuously. Compressor and fan run continuouly. Have replaced the: Control panel, mother board and two thermesters in the fridge. Evaporator coils cleaned. What is most likely cause of the fridge being to cold? Ads By Google Related Models |
Hi.
Most likely there is a broken door inside the air damper control Part number: WR49X10091 Here are the breakdown diagrams and Fresh Food Section parts for GE PSW26MSRESS - AppliancePartsPros.com You will need to replace the hole assembly. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Any other thoughts. Thanks, Frank |
Hi, Frank.
I suggest you to replace the part I listed above. Give it a day or two and if it's not going to work - return it back. I'm suggesting that because with all the parts you had replaced there is nothing left but the damper control. Post the results. Simon.
__________________
| Display Modes | |
| refrigator | hemat shah | Refrigerator & Freezer Repair | 1 | 03-14-2012 06:33 PM |
| Refrigator | webertony0852 | Refrigerator & Freezer Repair | 0 | 08-23-2011 10:37 AM |
| Cold/Cold, Warm/Cold and Hot/Cold Button Settings do not trigger the Rinse cycles | ralphdisimone@gmail.com | Washer Repair | 1 | 10-12-2010 02:55 PM |
| Refrigator | playtex | Refrigerator & Freezer Repair | 0 | 06-19-2010 10:21 AM |
| Refrigator | Champion | Refrigerator & Freezer Repair | 2 | 11-17-2008 06:02 PM |
